new header panel with headlight adjusters? - JeepForum.com
post #1 of 9 Old 01-14-2015, 11:33 AM Thread Starter
AVGyj93
I recently ordered a new header panel for my Grand Cherokee, and it didn't come with headlight adjusters, the ones where you use a allen head to adjust them horizontally and vertically. So I got the header panel just bear and I don't have an old one to pull the adjusters off of and implant in the new panel. How do people go about swapping in new header panels and adjusters when it seems like I can't even get the old adjusters out of my broken header panel and I can't find them online anywhere to install in this new one? All I see are the studs with a white plastic piece on it when I type in grand cherokee headlight adjuster on google or ebay. How do I get the whole mechanism for it? The black piece that u have to use a Allan to adjust it? I need those things. Thanks for the help guys
AVGyj93 is offline
post #2 of 9 Old 01-14-2015, 11:45 AM
kg6mov
Hears the voices
kg6mov's Avatar
Kolak can sell you new adjusters. Give him a PM.
kg6mov is offline
post #3 of 9 Old 01-14-2015, 08:50 PM
1998_ZJltd
one of the pairs you take out the two screws and then it slips right out .... the other you turn the adjuster and thread the horizontal threaded pin out then remove the two screws and the the base comes out ... put it in the new header panel and run the adjuster in reverse and thread the horizontal back in .....
I just did this two weeks ago and had absolutely no issue ..... look at them again and you will see it ....
1998_ZJltd is offline
post #4 of 9 Old 01-18-2015, 01:56 AM
travisyoung
1994 ZJ
I did this exact thing. I just ended up going to a JY and pulling a whole header panel with adjusters still in it
travisyoung is offline
post #5 of 9 Old 01-18-2015, 05:30 PM
jrusse
jrusse is offline
post #6 of 9 Old 01-18-2015, 05:41 PM Thread Starter
AVGyj93
K ill find me the cheapest one with adjuster holes pre drilled. Thanks y'all!
Sent from my Samsung Galaxy SIII using JeepForum
AVGyj93 is offline
post #7 of 9 Old 01-18-2015, 06:18 PM
jeeepguy
jeeepguy's Avatar
Dual posts on the same thing?
Morris 4x4 has the adjusters in stock.
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
post #8 of 9 Old 02-02-2015, 03:17 PM
pupster123
I lost all my headlight hardware. The problem is the post without the torx adjuster. I never got a measurement for how long its supposed to be. I didn't lose the regular (torx) adjusters, just the short posts. Anyone have an initial measurement I can start from?
pupster123 is offline
post #9 of 9 Old 02-02-2015, 03:19 PM
pupster123
It's a 98 grand cherokee. You might need that bit of info to help me.
