New Guy with a never before seen problem. - JeepForum.com
 1Likes
post #1 of 17 Old 07-27-2018, 08:40 AM Thread Starter
BlueMagnus
BlueMagnus's Avatar
Hello all, new guy here. Just got my jeep a little over a month ago. I have been undoing everything the P/O had done. Got it for a steal so I'm not too upset. It's been great to me. High enough to do my own oil changes. Engine is easy to navigate through. The interior is simple to test and diagnose. I have not gone off road with it yet but it can climb curbs easily.
So now the problem:
When ever I press the brake pedal, all the interior lights dim. The overhead console dims, the VIC dims and the dash lights dim. All other lights were removed by the P/O becaussssseeee they do not turn off and drain the battery quite fast. I switched the headlight/dimmer switch for a new one, still the same issue. Has anyone ever heard of this problem? I undid this horrendous wiring job done to the radio in the hopes it was the cause, but it wasn't. Don't know what else it could be.
BlueMagnus is offline
post #2 of 17 Old 07-27-2018, 08:51 AM Thread Starter
BlueMagnus
BlueMagnus's Avatar
1997 Jeep Grand Cherokee Limited V8*
I donít know much else about the Jeep because it came bare.
Sent from my iPhone using Tapatalk
post #3 of 17 Old 07-27-2018, 09:27 AM
Mr. Puddles
Is this only when moving or do they do it when you are sitting still?
Follow the build!
2002 Dakota aka Winnie aka Mad Max
1996 Grand Cherokee aka Puddles aka Pikey Life
Originally Posted by kg6mov View Post
The 4.0 is dumb old tractor motor, itís too stupid to know itís supposed to die.
Mr. Puddles is offline
post #4 of 17 Old 07-27-2018, 09:38 AM
1996maroonzjf
1996maroonzjf's Avatar
You might want to look at the abs module. They sometimes will stay active and do some screwy things after the car is shut down and drain the battery. Might also be related to why your lights dim when you brake.
-Tim
(2) '96 4.0s
#1-'10-'18
#2- HP30/Ford 8.8 - 4.56, OME HDs, 5100's, IRO Adj Arms/Track Bars
1996maroonzjf is offline
post #5 of 17 Old 07-27-2018, 10:12 AM Thread Starter
BlueMagnus
BlueMagnus's Avatar
When parked and the car is on, pressing the brakes will dim everything. While driving same issue.
post #6 of 17 Old 07-27-2018, 10:34 AM
Mr. Puddles
Try disconnecting the brake light switch and see if it still happens. If it does be ready to start your diag process
jtec likes this.
Follow the build!
post #7 of 17 Old 07-27-2018, 10:50 AM Thread Starter
BlueMagnus
BlueMagnus's Avatar
I actually tried it yesterday, it did stop the issue. I figured "hey issue's gone I'll drive like this" till I remembered I need the brake lights.
post #8 of 17 Old 07-27-2018, 11:01 AM
Mr. Puddles
Kind of an important item.
Pull the brake light bulbs and try again. Also check that they are the correct bulb number.
Follow the build!
post #9 of 17 Old 07-27-2018, 11:37 AM
jtec
jtec's Avatar
2014 JK Wrangler
Mr. Puddles narrowed that down quickly,
Want to add check trailer harness wiring if bulb check is not the end of hunt.
jtec is offline
post #10 of 17 Old 07-27-2018, 11:50 AM
Mr. Puddles
I'm going after easy things first. Ive seen the wrong bulb cause strange issues.
Follow the build!
post #11 of 17 Old 07-27-2018, 12:00 PM Thread Starter
BlueMagnus
BlueMagnus's Avatar
I'll try it as soon as I get off work. The P/O had installed some bright blue reverse lights and my VIC says I have a rear lamp failure. I ignored it because lights worked well enough.
post #12 of 17 Old 07-27-2018, 01:06 PM
Mr. Puddles
Check the wiring and connectors for everything. If someones rigged something there is no telling if the wiring was damaged
Follow the build!
post #13 of 17 Old 07-28-2018, 06:41 PM Thread Starter
BlueMagnus
BlueMagnus's Avatar
SOLVED! I removed all the bulbs the P/O installed. The VIC stopped showing fail lamp. The console stopped dimming. Thanks for the help!
post #14 of 17 Old 07-28-2018, 11:21 PM
Mr. Puddles
Good to hear. Those auto zone specials are complete garbage. I spend my dime with superbrightleds.com
Sent from my HTC6545LVW using Tapatalk
Follow the build!
post #15 of 17 Old 07-29-2018, 01:50 PM Thread Starter
BlueMagnus
BlueMagnus's Avatar
Theyíve never given you an issue? Iím looking for brighter headlights.
