Need answer for front driveline - JeepForum.com
post #1 of 3 Old 04-19-2011, 03:32 PM Thread Starter
xlr857
Ordered rc 4" x-series kit, and my 33" tires yesterday ive been reading on replacing the crappy cv front driveshaft. Should i just wait to see if i have vibrations or issues. Im not real confident on getting the pinion nut torqued right. Is there any straight bolt on options. i have 96 GC limited. On my research i thought if you had adjustable arms you wouldnt have vibrations due to being able to adjust the angles.
xlr857 is offline
post #2 of 3 Old 04-19-2011, 04:12 PM
mrfister11
yes there is an alternative without changing yoke.. my 95 had a chrysler driveshaft with the flange like the cv style on it. boy was it beefy.. but my 96 i lifted 6.5 didnt have a vibration. no tc drop either.. also i adjusted my control arms to make the pinion angle stock so the angel was also kinda bad.. but it did rip apart first ditch i went through because it was seperated too far.. so that could be an option for you.. i would sell you the one i have cheap but its for 95 so its a little longer because i just tried to put it in my 96. also do not adjust your pinion angle to help the driveshaft as you will jack with the caster and also the steering angle and the track bar and the spring.. but since you are only 4 inches idk.. i would try the option with that big round flange if you dont want to replace yoke.. one more thing the 95 had the cv style till my girlfriend ripped it to pieces.. so thats what the dealership put in it
mrfister11 is offline
post #3 of 3 Old 04-19-2011, 09:18 PM
Erbo1Kanerbo
Erbo1Kanerbo's Avatar
two options: 1) get a Flange adapter which will have a ujoint at the axle end and then you get a new driveshaft with ujoints at both ends or 2) go to a junkyard and find an xj or zj with ujoint at the axle end take that and the driveshaft. I dont know what year your jeep is so i cant help you with what year jeeps to take the yoke and driveshaft from but thats what i did. I have a 3.5" lift and my cv driveshaft started to bind up so i went to the junkyard pulled the yoke and driveshaft and wala
Edit: i see you have a 96, take a driveshaft and yoke out of a 96+zj for a direct swap im not sure about xjs you may need to modify driveshaft from them but you can take their yoke for sure
ZJ Build thread:
ZJ's: If you dont know what it is you cant afford it.
Erbo1Kanerbo is offline
no front driveline with a 249 MoToRNecK ZJ Grand Cherokee Forum 3 09-03-2010 12:51 AM
Need a quick answer! Whining noise in the front after lift BlackbeastZJ ZJ Grand Cherokee Forum 9 04-22-2010 12:46 PM
front driveline snapped Help!! Pizzola89 ZJ Grand Cherokee Forum 5 11-17-2009 03:02 AM
Front driveline vibes ZJ_Richie ZJ Grand Cherokee Forum 4 07-20-2009 04:14 PM
Front end clunk, the definitive answer? handee521 ZJ Grand Cherokee Forum 3 11-05-2008 06:26 PM
