My 98 4.0s ac compressor cycles quite often - JeepForum.com
post #1 of 9 Old 07-06-2020, 11:09 PM Thread Starter
8v-of-fury
Could that be related to a pressure switch saying yay or nay to the system?
Are these compressors variable (no clutch actuation whilst operating)
Or the cycle of the clutch every so often type?
'98 ZJ 4.0/242, Locked d30/d35, 31x10.5x15, 2" BB w/ Bilstein 5100's
8v-of-fury is offline
post #2 of 9 Old 07-07-2020, 02:37 AM
Zilliver
Seems the system is a bit low on freon.
98 Grand Cherokee 5.9 - daily
95 Grand Cherokee 5.2 - offroad
Zilliver is offline
post #3 of 9 Old 07-07-2020, 08:10 AM
LordHobbit
LordHobbit's Avatar
Yep, refrigerant is low. If you don't have the tools, take it to a competent shop to check out the system, full vacuum and recharge.
Or if you don't care for it to be checked out for leaks, one of those refill cans can help for the season.
93 red ZJ 196k 4.0. Spent more money than I should have ...
LordHobbit is offline
post #4 of 9 Old 07-07-2020, 06:57 PM Thread Starter
8v-of-fury
I am sure I checked it out previously with the gauges and the pressures were fine.
But as I have just learnt on my volkswagen, the compressor has a controlled valve that steadies the pressures pretty much always.
At about 90f, I am seeing i want like a low of 45-50psi and
post #5 of 9 Old 07-07-2020, 06:58 PM Thread Starter
8v-of-fury
A high side of 150-200 area.
Sorry. Stupid phone browser.. haha
post #6 of 9 Old 07-07-2020, 08:05 PM Thread Starter
8v-of-fury
As I said earlier, I have checked the pressures in past years.. but because they were "okay" I didn't try adding any quickcool cans. However I did just have muchos luck on my Volkswagen.. It needed a compressor clutch coil, and then afterwards the AC would physically work, but not blow much more than 10* colder than ambient. I slowly added a can of the refrigerant while watching both low and high side gauges. And periodically feeling the vents.. Now it blows literal ice cold.. LOL
Perhaps I will try adding refrigerant to the Jeep to see if it does anything.
post #7 of 9 Old 07-07-2020, 08:06 PM Thread Starter
8v-of-fury
post #8 of 9 Old 07-11-2020, 11:10 AM Thread Starter
8v-of-fury
So I did have a half can of r134a equivalent sitting around, i added it slowly to the system. It made quite the difference in the coolness of the system.
Are these compressors internally regulated by way of a TXV? or are they the type to cycle on and off?
post #9 of 9 Old 07-11-2020, 08:14 PM
jeepjeepster
Nope, just on and off...
WJ's got the expansion valve.
1994 ZJ-I6 w/270,000 mi
1998 ZJ 5.9 w/66,000 mi Slate Black
2004 KJ w/108,000 mi
jeepjeepster is offline
