my 94 ZJ is having an issue with the fuel gauge - JeepForum.com
post #1 of 4 Old 02-05-2015, 06:03 PM Thread Starter
cirwin144
1994 ZJ
So to start off with I have been crawling all over the ZJ forums and there are a couple threads already that are similar but none that exactly answer my question.
I bought the jeep from a highway patrol impound lot with 100k so I have no idea about the history of it but the night I was driving it home I noticed the overhead display for DTE just read "OC" which wasn't a huge deal since I was only paying $900 for it and everything else was working. but a couple weeks after I bought it the gauge dropped to empty and its sat there through about four tanks of gas.
I finally had time this week to drop the tank and check out the float. and I hit it with an ohm meter and it ranges between 5.5 and 3 depending on where I position the float so I'm assuming its still working which leads me to believe its a wiring issue but I have no clue which wires go where and am in dire need of some sort of diagram or any advise on the issue period.
cirwin144 is offline
post #2 of 4 Old 02-06-2015, 03:50 AM
dflewelling
As for the DYE reading OC, that's a fuse/relay issue iirc. My overhead display reads OC for outside temp., I believe the related fuses sit literally beneath the glove box interior.
dflewelling is offline
post #3 of 4 Old 02-06-2015, 08:27 AM
Cbob4
Cbob4's Avatar
When the solder joint on the ground wire on my float broke, my gauge and DTE did the exact same thing. If it was a blown fuse issue with the O/H, it wouldn't display at all.
Remember, floats (and thus the fuel gauge readings) work on resistance to ground. No "good" ground, no reading...
Cbob4 is offline
post #4 of 4 Old 02-06-2015, 02:33 PM Thread Starter
cirwin144
1994 ZJ
thank you I'll look into those relays behind the glove box.
but as far as solder joints go I checked all the ones ones on the pump assembly so its fairly safe to say that the issue isn't down there. unless the ohms its reading aren't right. but I cant seem to find any info on what the resistance is supposed to be. . .
fuel level sensor , fuel tank , wiring diagram
