Mousey Locker - JeepForum.com
 2Likes
post #1 of 16 Old 09-27-2020, 11:26 AM Thread Starter
BobaSeth
Mousey Locker
I found a VERY clean 98 Laredo. Rust on the driveline components but VERY little rust on the body, floor , and sub frame. Super solid. Owner said it didn't always shift out of 1st gear and it had a ruptured brake line (rusted where the front passenger line went through the grommet in the inner fender. Around here, it's almost impossible to find ZJ's that aren't rusted all to hell. I couldn't test drive it, but I got to hear it run. It was wicked cheap and the guy even offered to deliver it. It was hard to get up under it in the guys yard, but I could see that the underside was solid, it started easily and ran well, so I bought it.
Fixed the brake line, took it for a drive to check out the trans and heard a wicked metal on metal sound up front.
Jacked it up, first, noticed there was no front driveshaft. Nice of them to tell me that. Then I noticed an obscene amount of play in the yoke on the back of the diff.
This was also not a good sign
BobaSeth is offline
post #2 of 16 Old 09-27-2020, 11:28 AM Thread Starter
BobaSeth
so I pulled the cover and found
BobaSeth is offline
post #3 of 16 Old 09-27-2020, 11:30 AM Thread Starter
BobaSeth
cleaned out the mouse nest and bearing pieces and found the carrier was hammered all to crap
BobaSeth is offline
post #4 of 16 Old 09-27-2020, 11:32 AM Thread Starter
BobaSeth
pinion has no teeth
BobaSeth is offline
post #5 of 16 Old 09-27-2020, 11:34 AM Thread Starter
BobaSeth
all three bearings are shot, pinion and carrier are toast, right front axle is misisng, front driveshaft is missing, left front axle is sheared off at U joint and other end is siezed in the carrier and I can't get it out.
Good times,
BobaSeth is offline
post #6 of 16 Old 09-27-2020, 12:15 PM
1996maroonzjf
1996maroonzjf's Avatar
Nice score on the ZJ!
Looks like a perfect opportunity to swap in a High pinion Dana 30 from an XJ!
-Tim
(2) '96 4.0s
#1-'10-'18
#2- HP30/Ford 8.8 - 4.56, OME HDs, 5100's, IRO Adj Arms/Track Bars
1996maroonzjf is offline
post #7 of 16 Old 09-27-2020, 12:24 PM Thread Starter
BobaSeth
Perfect opportunity to put in new control arm bushings too since it will be out anyway
BobaSeth is offline
post #8 of 16 Old 09-28-2020, 07:33 AM
LordHobbit
LordHobbit's Avatar
That is scary people let their vehicles get that bad. Thank you for rescuing.
BobaSeth likes this.
93 red ZJ 196k 4.0. Spent more money than I should have ...
LordHobbit is offline
post #9 of 16 Old 09-28-2020, 01:03 PM Thread Starter
BobaSeth
still trying to get that axle out, still no luck.
I know I could just swap out the whole assembly, but I have no way to get an axle assembly home
BobaSeth is offline
post #10 of 16 Old 09-29-2020, 07:28 AM
LordHobbit
LordHobbit's Avatar
Could you rent a car?
post #11 of 16 Old 09-29-2020, 10:40 AM Thread Starter
BobaSeth
My best friend just told me to use his truck :]
Going to pickup an xj high pinion tomorrow :]
1996maroonzjf likes this.
BobaSeth is offline
post #12 of 16 Old 09-29-2020, 11:05 AM Thread Starter
BobaSeth
well, figured it would be a good idea to ask for pics of the high pinion before making the 3 hour drive each way.
BobaSeth is offline
post #13 of 16 Old 09-29-2020, 11:10 AM
1996maroonzjf
Yikes...
Just an FYI on the HP30 - XJs don’t use cam bolts in the lower control arms to set caster like the ZJ does, so you will need adjustable lower control arms to dial in your alignment.
-Tim
(2) '96 4.0s
#1-'10-'18
post #14 of 16 Old 09-29-2020, 11:13 AM Thread Starter
BobaSeth
Yikes...
Just an FYI on the HP30 - XJs donít use cam bolts in the lower control arms to set caster like the ZJ does, so you will need adjustable lower control arms to dial in your alignment.
Oh wow, than you SO much, I did NOT know that. That's an expense I can't handle right now. Right now I just need to get this on the road. Looks like I dodged a bullet on that one :]
BobaSeth is offline
post #15 of 16 Old 09-29-2020, 02:05 PM
jeeepguy
jeeepguy's Avatar
Where are you located!? Around here I can get a stock D30 complete for like $100... just bolt it up and go
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
