More complications w/ lift install... - JeepForum.com
 1Likes
  • 1 Post By nickfast
post #1 of 10 Old 03-12-2019, 12:50 PM Thread Starter
dyland123
Hate to start a whole new thread for a simple issue but I'm slap out of ideas soo...
Went to put in the new adjustable track bar and everything went fine until I got to the passenger side at the axle. I got the bolt in with a washer and lock nut (included) on the other side. Went to tighten it down and it just spins. Tried backing it out, more spinning. It seems that the nylon lock nut is stripped, no mater how well I hold on to it the bolt will spin inside the nut and not back out or tighten. I've tried vice grips on the nut while pulling away from the bolt to see if I could get it to start coming off and it wont. Also a flathead putting pressure on the bolt head and still nothing. Dont have room to wedge anything between the nut and the bracket...Once I get it out I guess I can just replace it with a regular nut and washer but in the mean time I have no clue how to get it out... awfully tight space isn't any help.
Tried to get a pic where you could see the other side with the nut but its tucked back in there.
dyland123 is offline
post #2 of 10 Old 03-12-2019, 01:12 PM
igorhandsome
igorhandsome's Avatar
I'd definitely grab a new locknut
igorhandsome is offline
post #3 of 10 Old 03-12-2019, 01:16 PM
kg6mov
Hears the voices
kg6mov's Avatar
From the description, I think you’re left with drilling out the head of the bolt.
Can you post more pics? Your axle side trackbar mount is interesting.
kg6mov is offline
post #4 of 10 Old 03-12-2019, 01:18 PM
nickfast
Isn't that supposed to be on the inside of the bracket?
Also notice that with that reinforcement plate on the front, the track bar is not sitting square.
1996maroonzjf likes this.
nickfast is offline
post #5 of 10 Old 03-12-2019, 01:33 PM
CatSplat
CatSplat's Avatar
1994 ZJ
That was my initial reaction as well. An axle-side trackbar mounted in single-shear is likely to cause instant death wobble while tearing the bracket apart. The end should be inside the bracket ears, even if the backside nut is a challenge to get to (the OEM was a flagnut but you can get a normal one in there with a bit of work).
1994 5.9L ZJ | IRO 5.5" CPLA | NP242 | 17" JK Moabs | 32" BFG MT KM
The Jeep of Theseus
CatSplat is offline
post #6 of 10 Old 03-12-2019, 01:43 PM Thread Starter
dyland123
OK soooo yep I have apparently lost my mind and mounted it wrong I suppose if anything its good that I had it mounted wrong when I discovered the locknut was stripped because it would have been even harder to get off if I had it in there right haha. Nonetheless I still have to find a way to get this off so I can get it actually mounted properly... I guess I can go buy some carbide bits or something, I only have drill bits for wood!
post #7 of 10 Old 03-12-2019, 01:44 PM
97Mule
97Mule's Avatar
Cut the bolt head off.... get a better quality bolt & nut.
97Mule is offline
post #8 of 10 Old 03-12-2019, 01:48 PM
CatSplat
CatSplat's Avatar
1994 ZJ
Angle-grind the bolt head off, punch the bolt through. You may need to cut the bolt shank as well to fit the remains of the bolt out from the bracket.
The Jeep of Theseus
CatSplat is offline
post #9 of 10 Old 03-12-2019, 02:09 PM Thread Starter
dyland123
got it ground off and taken out. Thanks so much for the help that would have been a disaster if I had left in mounted like that!!
post #10 of 10 Old Yesterday, 08:16 PM
LittleFootZJ
I would just use a cutoff wheel or a sawzall and cut the nut/bolt off of the backside and replace with a grade 8 bolt and new nyloc nut. I hate drilling out bolts so just lobbing it off is always easier if you can get to it. Definitely mounted in the wrong spot too but that has already been covered.
*edit* using Tapatalk and it didnít update the thread for some reason. Glad you got it taken care of haha
Sent from my iPhone using Tapatalk
LittleFootZJ is offline
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3853 02-12-2019 09:15 AM
Modification Write Ups and Index dvdsjk WK2 Grand Cherokee Forum 89 11-04-2018 02:13 PM
Upcoming Lift Install, Front Track Bar? DT5150 TJ Wrangler Technical Forum 19 03-12-2018 04:18 PM
What is a CV shaft and why do I want one? Unlimited04 TJ Wrangler Technical Forum 175 02-23-2018 10:17 PM
Call me stupid, tell me I didn't search the threads-too bad I did. AAl vs RLS HornedFrogHooah XJ Cherokee Technical Forum 23 04-24-2010 12:33 PM
