mopar oil pump on 5.9 - JeepForum.com
post #1 of 6 Old 01-01-2020, 01:05 PM Thread Starter
SweetPEALvr15
looking at oil pumps v. performance oil pumps and mopar has regular oe one (part number - MOPAR 2806270AB) but i saw this mopar "performance one (part number - Mopar Performance High Performance Oil Pumps P4286589) that says it doesn't fit but the picture looks exactly the same, I'm wondering if anyone has used this one on their 5.9 or can direct me to a trusted high volume/ performance oil pump
Screen Shot 2020-01-01 at 11.32.14 AM.jpg   Screen Shot 2020-01-01 at 11.31.58 AM.jpg
SweetPEALvr15 is offline
post #2 of 6 Old 01-01-2020, 01:15 PM
Wolfeman1992
Wolfeman1992's Avatar
1994 ZJ
Those arent the same, the "performance"one is more than likely for a 5.9 truck with a external oil cooler
94 ZJ 4.5" on 31s
Wolfeman1992 is offline
post #3 of 6 Old 01-01-2020, 01:53 PM
Timo_90xj
Timo_90xj's Avatar
I bought a Melling high volume pump to my 5.9, it gave a slight bump on the oil pressure and has been working flawlessly.
***Under construction***
Timo_90xj is online now
post #4 of 6 Old 01-02-2020, 05:41 AM
V8GCZJ
P4286589 is for small blocks, It's basically a high volume pump. If you want more pressure mopar performance offers a spring kit to boost it part # P3690944
V8GCZJ is offline
post #5 of 6 Old 01-02-2020, 10:02 AM
jrcromwell
jrcromwell's Avatar
Edited for bad info: MoparsOnly is correct the M72 are used in the LA small blocks, Magnum small blocks, V6 and Polysphere engines.
I purchased the Melling pump M72 when I did mine last year. The high volume is the M72HV.
jrcromwell is offline
post #6 of 6 Old 01-04-2020, 07:17 PM
MoparsOnly
The LA part # for an O/P is the same as It Is for a magnum M72 and M72HV
MoparsOnly is offline
5.9l grand cherokee zj , jeep , oil pump
