Master Switch Issue Driver Door - JeepForum.com
post #1 of 3 Old 01-20-2020, 09:13 AM Thread Starter
greers85
Need Help Trouble Shooting a Switch Issue.
I have removed this switch in the past when working on the door. I had been having minor issues with it not controlling any locks or windows at all. However each individual door works fine, my question come in at the connections itself.
I am seeing 3 connections on the back but only two wires in the door harness itself. Is this third connection an extra for the adaptation to another model or is there a chance that i have lost a pigtail at some point? I have verified that i do not have any wire breaks in the harness between the door and the body so it has to be a bad switch unless i am missing a wire. I am having some difficulties finding any photos of the connections. Any help would be appreciated.
Also my horn honks continually when the fuse is in. Could these issues be related?
greers85 is offline
post #2 of 3 Old 01-20-2020, 11:33 AM
wingless
wingless's Avatar
1994 ZJ
Welcome to the forum.
The power window / locks problem sounds like broken door jamb wiring.
This topic shows my door jamb wiring repair.
The horn problem sound unrelated, maybe a stuck horn button or (much less likely) a short circuit in the wiring.
wingless is offline
post #3 of 3 Old 01-20-2020, 02:54 PM Thread Starter
greers85
Those Pictures are great! I will make a second pass inside that boot. I had it peeled back from the body as well as the door yesterday and did not see nor feel any breaks, thank you again for the information.
greers85 is offline
