Mark's V8 ZJ - Page 12 - JeepForum.com
 66Likes
post #166 of 186 Old 07-14-2021, 01:33 AM Thread Starter
Mark-318-IT
Originally Posted by Mr. Puddles View Post
What did those come out of? Direct bolt in?
they are from a fiat coupe 20V turbo (keep in mind that i'm in italy).
unluckily not even close to direct bolt in....i'm building some kind of a rack to bolt them in.
360swapped:np242swap,shift kit,BOLT ONs,ome HD coils,aussie locker,dana30hp trussed
Mark-318-IT is offline
post #167 of 186 Old 08-23-2021, 01:46 AM Thread Starter
Mark-318-IT
hey guys,
i finally put the Z back together one more time.
taking it easy for a while, need some kind of a break in.
does not seem like "super fast" as i was expecting, keep in mind that i'm completely out of tune though. gonna take a dyno sessione after break in.
still need to complete some minor stuff like dual exhaust, really hoping it stays together this time.
a few friend came to say hello , couple 4.7s and another 5.9.
post #168 of 186 Old 08-24-2021, 01:34 AM Thread Starter
Mark-318-IT
hi guys,
did some minor stuff yesterday: tightened track bar bolt, greased the sway bar bushing and reversed a sway bar bracked (it was installed upside down), cleaned the coolant reservoir and greased all the steering components. unluckily all the boots of the steering components are shot so grease is spilling out.
gonna do some detailing today.
a friend of mine's grey niner and my pontiac in the back.
BlaketheSnake likes this.
post #169 of 186 Old 08-25-2021, 01:39 AM Thread Starter
Mark-318-IT
done some detailing yesterday, obviously we got rain tonight lol
washed the engine and the suspensions too.
i know washing the engine ain't the brightest idea, but after all this work it was simply filthy. i couldn't tell if there were any leaks or anything.
Timo_90xj and PolkaPower like this.
post #170 of 186 Old 09-01-2021, 08:30 AM Thread Starter
Mark-318-IT
looks like i'm having some transmission codes:
p0711 44re transmission fluid temperature sensor A circuit range / performance is still pending. other ones are stored.
https://www.jeepforum.com/forum/f13/...where-1145768/
https://www.jeepforum.com/forum/f13/...sensor-708858/
https://www.jeepforum.com/forum/f13/...sensor-828009/
found these.
everything in this tranny is brand spankin new.
could be a faulty new part?
https://www.rockauto.com/en/catalog/...modulator,8500
is this the correct part i need? or, is it normal with a full manual tranny?
thanks
marco
post #171 of 186 Old 09-01-2021, 09:25 AM
kg6mov
Hears the voices
kg6mov's Avatar
That's within the range for infant mortality, but I would tend to assume a wiring fault with that many codes.
kg6mov is online now
post #172 of 186 Old 09-01-2021, 02:48 PM
riiz
riiz's Avatar
All those codes are generated by that one solenoid/sensor. But it is either a damaged solenoid or plug/harness is damaged. Which brand of solenoid did you go with, the rockauto link shows all 4?
riiz is offline
post #173 of 186 Old 09-13-2021, 02:37 AM Thread Starter
Mark-318-IT
just came back from a few days of holiday, i did not go with the Z lol.
no news on those codes. need to check out the issue deeper.
only thing i did is adjust the steering box a lil. feeling better now. i'm running the steering box brace, "the cure", stronger control arms. i don't think i can do much more to improve the steering feel on my rig. what do you think?
post #174 of 186 Old 09-15-2021, 11:21 AM Thread Starter
Mark-318-IT
ordered an euro-spec , passenger side and with the electrical adjustment headlight from ebay and obviously got the NON electrical one. PITA
i already contacted the seller...
post #175 of 186 Old 09-16-2021, 02:31 AM Thread Starter
Mark-318-IT
found these.
thanks
marco
quoting myself,
contacted good old martin, he says that Codes are to be expected. The PCM no longer receives signals from the Pressure/Temp sensor or the Governor Pressure Solenoid, thereby triggering the MIL.
i'll try to remove them when i tune it. i don't like the cel always on.
300km on the tranny, 1800km on the engine.
post #176 of 186 Old 09-16-2021, 05:47 AM
Zilliver
Maybe you can fake the PCM and connect some small light bulb as a tranny solenoid
98 Grand Cherokee 5.9 - sold
95 Grand Cherokee 5.2 - sold
Zilliver is offline
post #177 of 186 Old 09-21-2021, 11:27 AM Thread Starter
Mark-318-IT
new headlights are in, and yes, i have the elctric adjustment lol.
need to adjustem manually though
post #178 of 186 Old 09-29-2021, 06:40 AM Thread Starter
Mark-318-IT
new windshield is up
post #179 of 186 Old 09-29-2021, 07:19 AM
KC7NOA
I love that they are so clear .. i need 4x !!!!
KC7NOA is offline
post #180 of 186 Old 10-01-2021, 10:48 AM Thread Starter
Mark-318-IT
those clear headlights help
inspection passed, now onto the dyno ....
01 WJ 4.7l dies 9 seconds after start and blows ASD fuse. tesco2 WJ Grand Cherokee Forum 17 01-24-2019 09:01 AM
1997 XJ Timing chain replacement askites96 XJ Cherokee Technical Forum 6 01-23-2019 08:32 PM
Mysterious axle rub marks montync ZJ Grand Cherokee Forum 2 01-14-2019 11:36 AM
2.5L distributor isn't lining up correctly bkaab Engines & Drivetrain 11 02-19-2018 07:34 AM
Timing chain sprocket alignment question. yellow85cj Jeep CJ Forum 13 01-27-2018 02:49 PM
