Lower control arm - JeepForum.com
 4Likes
  • 1 Post By Timo_90xj
  • 3 Post By Timo_90xj
post #1 of 9 Old 08-02-2021, 12:47 PM Thread Starter
dlk59
Lower control arm
Looking through the forums today I noticed the lower control arms on another ZJ. I then referenced my maintenance manual. I believe that some time in the past my lower control arms were installed upside down. U portion is facing down. Has anyone else ever seen this? Vehicle tracks great, steering is good, etc... Is this anything to worry about?
dlk59 is offline
post #2 of 9 Old 08-02-2021, 12:58 PM Thread Starter
dlk59
Let me clarify a bit --- installed with U down ---- manual shows a solid bar not a rolled steel U with flanges ones on truck. Looking at it it looks like it might hold mud where as if flipped over it would not. Do not know if these are original or aftermarket (no lift). Parts for sale look like what is installed - are not designated Left or right.
dlk59 is offline
post #3 of 9 Old 08-02-2021, 02:27 PM
kg6mov
Hears the voices
kg6mov's Avatar
Factory arms are stamped steel u shapes like what you're describing. The manual doesn't show the detail, but the top of the arm should basically look like the picture. The open side should be down towards the ground.
kg6mov is offline
post #4 of 9 Old 08-02-2021, 02:31 PM
yjsaabman
1930 CJ2
This. Stamped steel is the norm. It's cheap and it's strong enough for basic use.
Sent from my SM-G970U using Tapatalk
yjsaabman is offline
post #5 of 9 Old 08-02-2021, 05:21 PM
PolkaPower
PolkaPower's Avatar
They fold like paper on any hard surface off road...
Sent from my iPhone using Tapatalk
PolkaPower is offline
post #6 of 9 Old 08-02-2021, 06:46 PM
kg6mov
Hears the voices
kg6mov's Avatar
Yup
The front uppers are worse, bend then fatigue and break.
kg6mov is offline
post #7 of 9 Old 08-02-2021, 10:33 PM
Timo_90xj
Timo_90xj's Avatar
As mentioned, all eight OEM control arms are stamped/ pressed steel, U- shaped. Installed with the solid side up, open down. Yes, they fold like a taco if you go wheeling. They work for light wheeling on stock- height Jeep, that's about it.
That being said, the OEM control arms are actually supposed to fold like that - in an accident folding prevents the arms from penetrating into the cabin, or somewhat prevents them from getting into gas tank. In smaller accidents like driving into a ditch, the arms fold instead of bending the frameside brackets.
With aftermarket arms, all sorts of funky things can and do happen when the arms will not fail and the weak link is elsewhere in the suspension.
yjsaabman likes this.
***Under construction***
Timo_90xj is offline
post #8 of 9 Old 08-03-2021, 01:41 PM Thread Starter
dlk59
As they look relatively new (compared to rear), still mostly black, no bends or visible damage like in kg6mov pics, or drivability issues ----- I guess I will spend a day this weekend swapping them correct side up (if bushings look good still). My ZJ is a nice old stock equipment ride with light off-road use, but I'd hate for winter slide into the ditch or curbs to damage the attachment points. Thanks for the feedback and discussion!
dlk59 is offline
post #9 of 9 Old 08-03-2021, 01:45 PM
Timo_90xj
Timo_90xj's Avatar
Remember to tighten all CA bolts with the full weight of vehicle on axles, suspension at ride height.
If you tighten them when axles are drooping, CA bushings are binding and under rotational tension at ride height -> they will fail fairly quickly.
