Looks like someone took a dump in my radiator / coolant - JeepForum.com
 6Likes
post #1 of 17 Old 04-19-2019, 12:27 PM Thread Starter
IMMORTEN
IMMORTEN's Avatar
This canít be good, can it?
I have never seen this before in any of my cars.
Radiator was replaced like a year ago or so by the previous owner, so itís pretty new.
Sent from my iPhone using Tapatalk
IMMORTEN is offline
post #2 of 17 Old 04-19-2019, 02:27 PM
zjosh93
What kind of anti-freeze/coolant did they use? Looks like corrosion. Might need more coolant.
Might also check to see if you're getting stray voltage in your coolant. Easy to do with a multimeter. Just put the negative lead on the battery negative post and put the positive lead in the coolant. Should be less than 0.3 or 0.5 volts IMS. Any more and you need to fix your engine grounds.
zjosh93 is offline
post #3 of 17 Old 04-19-2019, 05:46 PM
RedZeeJay
I've only seen this kind of thing on GM vehicles with Dex-Cool. Either the coolant is left untouched for many, many years or is mixed with regular ethylene glycol (traditional green coolant). I don't think either of these is your issue to be honest.
None the less, at this point I'd perform a coolant flush at the very least.
RedZeeJay is offline
post #4 of 17 Old 04-20-2019, 12:54 AM Thread Starter
IMMORTEN
IMMORTEN's Avatar
I havenít got a clue to honest about what and how much coolant they used.
Thanks for the tip about the voltage, Iíll check that
Thereís a high possibility of that, because they donít sell the Green coolant over here.
https://www.thansen.dk/bil/olie-og-k...d/n-495911436/
They only sell the red, yellow and blue kind, and by the looks of it they have used the red kind because the overflow tank has red coloring all over it.
So this raises my next question; which of the coolants can I use as an alternative to the green kind of coolant?
Red, yellow or blue kind?
IMMORTEN is offline
post #5 of 17 Old 04-20-2019, 07:21 AM
V8GCZJ
What is in it now? You have rust in the cooling system probably because the previous owner had a leak and he just added water. Do a good flush and put in the red/orange antifreeze(dex cool or better) and you'll be fine.
https://www.hemmings.com/blog/2014/0...of-antifreeze/
V8GCZJ is offline
post #6 of 17 Old 04-20-2019, 07:53 AM
ScowHound
2008 WK
may be corrosion too, but could be a huge dose of "Bahrs Leaks" or whatever they call it these days.
ScowHound is offline
post #7 of 17 Old 04-20-2019, 07:54 AM
RedZeeJay
I'll let someone smarter than me answer on the type of coolant that is best to use in place of the traditional green stuff. I would definitely recommend flushing out the system good.
Just for comparisons sake, here is a photo from an Chevrolet Impala that had Dex-Cool congeal up and create a similar situation. This wasn't my vehicle so I really don't know if they mixed coolants, but that was the story they told me.
IMMORTEN likes this.
post #8 of 17 Old 04-20-2019, 08:43 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
I'd hazard to guess that someone dumped some sort of stop-leak into it, especially you say they replaced the radiator - stop-leak to get them home, then install the new part.
I will say though, my wife's 06 Liberty has that kind of mess going on, but it is reddish, like the coolant Chrysler put in from factory was getting crusty.
Put some washing soda in there, add water, and run it up to temperature for a while. Drain that, flush it, and refill with fresh good quality red.
Rick
Cutlass327 is offline
post #9 of 17 Old 04-20-2019, 10:55 AM Thread Starter
IMMORTEN
IMMORTEN's Avatar
Okay wow that was an interesting discovery I just made.....it was ALL rusty water in the system.....not a single drop of coolant in the system at all
Just look at this:
Look at all this rust gathered at the bottom:
I replaced it with the red coolant as it looks like it was previously used on my Jeep
IMMORTEN is offline
post #10 of 17 Old 04-20-2019, 11:00 AM Thread Starter
IMMORTEN
IMMORTEN's Avatar
I appreciate the kind help by the way
The Jeep community is really an amazing group of kind and helpful people compared to many other car communities out there.
I must say; the Jeep community by itself really makes it a pleasure to own a Jeep
Almost makes me not want to any other car brand for the rest of my life
RedZeeJay likes this.
IMMORTEN is offline
post #11 of 17 Old 05-14-2019, 11:32 AM
klaxmaster
klaxmaster's Avatar
Glad you discovered what it was.
My buddy and I had a similar experience with his mid 2000's impala with dex-cool. He got an oil change and the place topped off his coolant, but used regular ol' green. within 2 weeks, it looked like someone had eaten chipotle and taco bell for a month straight and then unleashed the contents of their bowels straight into his radiator.
And somehow that doesn't sound as bad as having 100% rust water run through your engines cooling system. o.O I'd check your water pump and theromstat, and consider replacing all your hoses.
If it ain't broke, fix it with a larger part.
klaxmaster is offline
post #12 of 17 Old 05-15-2019, 02:20 PM
Bmann412
Bmann412's Avatar
1930
Not to hijack this thread.but I am having a similar issue with the motor I swapped in to my Jeep. I have flushed the system twice but still end up with brown/ goopy coolant. Should I not be using the green colored coolant? I checked the coolant with a multi meter and it tested fine. It has a new thermostat,heater core,water pump and radiator and all new hoses.
1998 TJ 5.9l
1978 CJ7 Renegade
2013 JK
Bmann412 is online now
post #13 of 17 Old 05-15-2019, 04:04 PM
RedZeeJay
In my experience that goopy, clumpy stuff is hard to get out. On the Impala I encountered it on, we ended up flushing the system out a good 6-7 times. Yeah, seems excessive, but that's what we had to do to get the fluid even remotely free of "goopy-ness".
It should be mentioned that we used a radiator / coolant flush product from Prestone and distilled water for the majority of the flushes to save from wasting a ton of coolant.
Just my .02...
post #14 of 17 Old 05-15-2019, 04:45 PM
Bmann412
Bmann412's Avatar
1930
Just my .02...
Thanks for the quick reply. I will take you advice and pick up a couple bottles of coolant flush. Hopefully I can clear it all out. I am sure it is not good to have that stuff in the system.
1998 TJ 5.9l
1978 CJ7 Renegade
2013 JK
post #15 of 17 Old 05-15-2019, 04:56 PM
RedZeeJay
The owner of the Impala had found this YouTube video which we "loosely" followed a bit... Your mileage may vary with this video, but I'll link it here just in case...
Best of luck!
Fix or dump ernestoc33 Grand Cherokee General Discussion 1 04-18-2019 07:14 PM
