lift question - 98 5.9 - JeepForum.com
post #1 of 31 Old 03-25-2011, 06:07 AM Thread Starter
two_much_talk
1998 5.9
Just purchased this jeep. Don't like the way the 33's sit.
Was told it has an old sagging 3" front to back swap with 2" spacers.
There is 5.5" of wheel well clearance in the front and 7" of wheel well in the rear. Want to level it out.
TEMPORARILY I was thinking I'd get new 5.5" front springs. Later get 4.5" rears as money allows.
Can anyone tell from info given if buying the new front springs will level out the jeep?? I know this isn't exactly the best description but feel free to ask questions...
Side Note - the rear tires are not centered in the wheel well. Looking for upper/lower adj control arms for the rear.
two_much_talk is offline
post #2 of 31 Old 03-25-2011, 07:14 AM
speedbucket
appropriate spacers woul be the cheap route for the front, coils by preference
the arc the rear tire suspension travels on goes backwards/up at the same time. so you dont want the rear tire to be centered in the wheel well, you want it to be closer to the front
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #3 of 31 Old 03-26-2011, 03:07 AM Thread Starter
two_much_talk
thanks for looking and posting. I understand how the suspension moves when it cycles and am not new to lifted short arm suspensions. The rear axle placement statement was more of a "hey if your upgrading to long arms and have adj rear arms I'd be interested in buying them".
Back to the original question, since I'm not really sure how much lift I have in the rear, I'm sort of making an educated guess at what I need to level out the front. Again 5.5" of wheel well in the front and 7" in the rear. 33x12.5s on 15x10s with 3.75" of backspacing.
Does anyone have any idea if front 5.5" Rusty's springs will level out the rig??
Thanks
post #4 of 31 Old 03-26-2011, 03:56 AM
HeavyArms
jeep looks great!
ive heard that the rustys coils have sagging issues. ive heard nothing but good from BDS, IRO, and RE coils. ive heard that IRO and RE's 4.5" coils give around 5".
only other thing i have to add is that did you take the extra weight into concideration? between the v-8 and arb the front coils have there work cut out for them.
sooo you should let me take that arb off ur hands and lighten up the front! see i solved ur problem!
Wiggle wiggle wiggle
HeavyArms is offline
post #5 of 31 Old 03-26-2011, 07:11 AM
blackjack12982
blackjack12982's Avatar
1994 ZJ
You could measure and find out exactly how much lift you have still...
Measure from the center of your hub to the edge of your fender. 18" is roughly stock.
blackjack12982 is offline
post #6 of 31 Old 03-26-2011, 08:16 PM Thread Starter
two_much_talk
Originally Posted by HeavyArms View Post
jeep looks great!
Weight : yeah that's another reason I thought 5.5" in the front and 4.5" in the rear would work for me.
post #7 of 31 Old 03-26-2011, 08:16 PM Thread Starter
two_much_talk
Thanks ! that helps a lot !!
and that's the front axle right ? what's the measurement supposed to be in the rear ?
post #8 of 31 Old 03-26-2011, 08:51 PM
blackjack12982
1994 ZJ
We talked over texts, but for everyone else. The 18" measurement is for both front and rear. It's what they are new, so expect some degree of sagging, but that's a good number to shoot for.
post #9 of 31 Old 03-26-2011, 10:33 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
If you want to replace the springs, check out Iron Rock offroad.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #10 of 31 Old 03-26-2011, 11:18 PM Thread Starter
two_much_talk
thanks, will do ...
and thanks BlackJack - good talk
post #11 of 31 Old 03-27-2011, 12:11 AM
lauderdalechad
2006 WK
looks good! but imo those 10" wide rims make it look like crap, id chuck em if that was my ZJ!
lauderdalechad is offline
post #12 of 31 Old 03-27-2011, 02:34 AM Thread Starter
two_much_talk
I like fat rims/tires. My favorite rim tire package ( that I've owned ) was my 15x10 steel beadlocks with Comp Compound 38.5x16x15 Baja Claws ! Those wheels were amazing !!
Sexy Sexy !!
post #13 of 31 Old 03-27-2011, 02:46 AM Thread Starter
two_much_talk
been considering just ordering a complete kit since the cost of new shocks and springs isn't far off from an entire kit! I've heard the new Rough Country X series stuff is much better than the old stuff. Anyone have any experience with that ?
What I'm considering ....
4" RC - $750 6 control arms with single flex joints
4.5" IRO - $675 no control arms
4" Zone $583 4 fixed lower arms
post #14 of 31 Old 03-27-2011, 06:00 AM
HeavyArms
ive delt with the Zone kit and i like it other then it dosnt come with trackbars and the coils settle to around 3.5". we put 2" spacers on top and it worked out perfect.
post #15 of 31 Old 03-28-2011, 02:44 AM Thread Starter
two_much_talk
thanks. the Zone is out of the question now. sorry.
I've actually been toying with selling my entire suspension and buying a long arm now. . . .
I just don't have a good reason right now. i can adjust the arm lengths a little and clear the front a little more and the rear doesn't rub I just don't like the look and rake of the lift.
I bet if the lift were on another rig the front wouldn't sit as low cause I have that heavy bumper and winch up front.
I'm still a bit new to JeepForum - can I post a feeler thread asking for interest in my suspension??
NEWB 2" lift question: spring lift vs bb lift squiretdi ZJ Grand Cherokee Forum 4 01-12-2011 11:50 PM
lift question. thinking of going bigger and now i am slightly confused about old lift Irish_Assassin ZJ Grand Cherokee Forum 12 01-22-2009 02:17 PM
Lift Question - NO ITS NOT THE SAME OLD QUESTION - i hope Intense-Dakota ZJ Grand Cherokee Forum 15 02-08-2008 04:22 PM
Lift Question cadencedad ZJ Grand Cherokee Forum 3 11-23-2007 02:16 AM
Yes, another lift question bradhowald ZJ Grand Cherokee Forum 8 04-15-2006 12:17 PM
