LED headlamps - JeepForum.com
post #1 of 5 Old 07-07-2020, 01:39 PM Thread Starter
98Jeep4.0
LED headlamps
So I am wanting to convert my Headlamps to Led I have a 98 Jeep Grand Cherokee limited any suggestions? I bought a set on ebay but my high beams stay on
Stock sucks even small add-ons is better then stock
98Jeep4.0 is offline
post #2 of 5 Old 07-07-2020, 03:34 PM
dieselyota
I have HIKARI LED Headlight Bulbs Conversion Kit- 9004/HB1, 2019 New Gen of HIKARI, Adjustable Beam, 9600lm 6K Cool White they work very well.
Sent from my SM-G930W8 using Tapatalk
dieselyota is offline
post #3 of 5 Old 07-08-2020, 04:47 AM
V8GCZJ
You may want to search some of the "headlight upgrade" posts. Plenty of info there.
V8GCZJ is offline
post #4 of 5 Old 07-08-2020, 08:15 AM
LordHobbit
LordHobbit's Avatar
The challenge with LED headlamps is the diodes are not at the same place the original filaments are. That makes for a poor beam blinding traffic in front of you.
I found one set that mimics a 9004 close enough that I haven't changed it out in my Dakota yet, but that set is no longer sold.
93 red ZJ 196k 4.0. Spent more money than I should have ...
LordHobbit is offline
post #5 of 5 Old 07-08-2020, 08:25 AM
jay-h
That is frequently a problem (not mentioned by vendors, of course). Another issue is heat dissipation. An incandescent throws heat out with the beam as infrared, an LED (which is easily damaged by overheating) sheds heat through the base. True LED full headlamps are designed to carry a lot of heat out the back, lamp units designed for bulbs are not.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
