LCA bracket - JeepForum.com
 1Likes
  • 1 Post By Timo_90xj
post #1 of 15 Old 11-13-2019, 04:03 PM Thread Starter
avandyck
avandyck's Avatar
LCA bracket
Hi guys. Could you please tell me if it's normal for the driver side lower control arm bracket attached to the axle to look like crooked into the inner side? Maybe if you could share with me a picture of yours, will appreciate it. I just replaced both lcas and bushings and noticed it. Below there's a picture of it. I'm trying to fix a vibration coming from the front side like on the dash and steering wheel strating at 40mph and I'm a little lost. Just did alignment and wheel balance and got my u joints inspected, they look in good condition with no play. I still have to get the damper/stabilizer/steering strut replaced.
1997 GC ZJ 4.0 6cyl 4*4
IMG_20191113_164801_1573685991676.jpg   IMG_20191113_164747_1573686040502.jpg   IMG_20191113_164729_1573686102105.jpg
avandyck is offline
post #2 of 15 Old 11-13-2019, 04:13 PM
Mr. Puddles
If memory serves it does look correct. What transfer case do you have? I had a front end vibration that ended up being the centering ball in the front shaft double cardan.
Follow the build!
2002 Dakota aka Winnie aka Mad Max
1996 Grand Cherokee aka Puddles aka Pikey Life
Originally Posted by kg6mov View Post
The 4.0 is dumb old tractor motor, itís too stupid to know itís supposed to die.
Mr. Puddles is offline
post #3 of 15 Old 11-13-2019, 10:21 PM
Timo_90xj
Timo_90xj's Avatar
Nope, not normal. Someone has hit a kurb or driven into a ditch with that thing.
97Mule likes this.
***Under construction***
Timo_90xj is offline
post #4 of 15 Old 11-13-2019, 11:38 PM Thread Starter
avandyck
avandyck's Avatar
I have the 242 AFAIK. You mean the point where it appears to have 2 u-joints coming from the TC to the front?
avandyck is offline
post #5 of 15 Old 11-13-2019, 11:42 PM Thread Starter
avandyck
avandyck's Avatar
Even if the arm looks straight into its place? Doesn't look crooked or at an angle, compared to the one on the passenger side looks the same. I'm really confused, if anyone could take a picture of yours would be awesome
avandyck is offline
post #6 of 15 Old 11-14-2019, 12:02 AM
Timo_90xj
Timo_90xj's Avatar
Bracket and LCA should be at a right angle to the axle tube when looking from the front. In your pictures it looks like the bracket/ LCA do not sit correctly. Might be a camera angle thing though.. Can be easily verified with a right angle tool.
post #7 of 15 Old 11-14-2019, 05:39 PM Thread Starter
avandyck
avandyck's Avatar
I'll have them inspected then. Because it indeed looks out of angle like pushed to the center
avandyck is offline
post #8 of 15 Old 11-15-2019, 01:21 PM
Mr. Puddles
This thing
http://4x4icon.com/offroad/072107_fr...t/DSC06649.htm
The centering ball in mine went bad and was causing a vibration. With the 242 you can pull the front shaft and test drive it. That will confirm or eliminate drive shaft play
Follow the build!
post #9 of 15 Old 11-15-2019, 01:40 PM
Timo_90xj
Timo_90xj's Avatar
Now that I looked at a few old pictures of my XJs and the ZJ with OEM LCA brackets, I am 100% sure your bracket is bent. I was 99.99% sure before that If you had a welder it wouldn't be a big deal to replace the front LCA brackets - not having one I highly suggest hitting the local junkyards. It is not a good idea to drive around with bent control arm brackets.
Most 4.0s had 3.55 gears, V8 3.73; '96+ used short lo pinion, earlier were long lo pinion. Also check the pinion if it has yoke or CV flange, get the correct one for your front DS style.
post #10 of 15 Old 11-17-2019, 09:57 AM Thread Starter
avandyck
avandyck's Avatar
This thing
Now that I looked at a few old pictures of my XJs and the ZJ with OEM LCA brackets, I am 100% sure your bracket is bent. I was 99.99% sure before that <img src="https://www.jeepforum.com/ubb/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /> If you had a welder it wouldn't be a big deal to replace the front LCA brackets - not having one I highly suggest hitting the local junkyards. It is not a good idea to drive around with bent control arm brackets.
You 2 guys are great. Thanks for the advice. I will do that test drive without the DS to isolate the issue and hopefully find a solution, and the do the bracket.
I don't have a welder so replacing the thing from a jy means bring all the front axle home?
avandyck is offline
post #11 of 15 Old 11-18-2019, 01:33 PM Thread Starter
avandyck
avandyck's Avatar
I've figured out the vibration issue, the front cardan / drive shaft spins outta its place like up and down. Any advice on where to buy that piece?
avandyck is offline
post #12 of 15 Old 11-18-2019, 01:58 PM
Mr. Puddles
Spicer 211544x - non greasable
Spicer 211355x - greasable
The non greasable is easier if you dont want to mess with the hassle of grease points.
Follow the build!
post #13 of 15 Old 11-19-2019, 09:34 AM
CatSplat
CatSplat's Avatar
1994 ZJ
The non-greasable one requires the separate rubber boot that tends to wear out, which is an added cost. The greasable unit actually seems to be a bit better sealed than the non-greasable, FWIW.
1994 5.9L ZJ | IRO 5.5" CPLA | NP242 | 33" Cooper Discoverer STT Pro
The Jeep of Theseus
CatSplat is offline
post #14 of 15 Old 11-20-2019, 08:40 AM Thread Starter
avandyck
avandyck's Avatar
So, you're saying to just replace the u.joints or is that for a new DS?
avandyck is offline
post #15 of 15 Old 11-20-2019, 09:06 AM
CatSplat
CatSplat's Avatar
1994 ZJ
We're saying to replace the U-joints and centering ball assembly, the part numbers provided above were for the centering ball. To do a complete front shaft rebuild you will need 3 external-clip 1310 U-joints and a centering ball. It's a pretty straightforward task if you have a balljoint press handy.
The Jeep of Theseus
CatSplat is offline
