just used seafoam, now check engine light on - JeepForum.com
post #1 of 9 Old 10-15-2009, 05:16 PM Thread Starter
myjeeplovesmud
myjeeplovesmud's Avatar
what would cause this? i'd imagine it's a sensor getting a foul reading and will go away once completely out of the system. Any ideas???
2004 WJ Limited 4.7 H.O
K&N FIPK - Magnaflow Exhaust
17" XD Series Spy Rims- Custom Painted
ZONE 4" Lift With 32" Duratracs
Hella Lighting - Rola Rack - KOR 3/4 Spacers
IRO Sliders - Rusty's Hooks - Cobra CB
November 2010 GCOTM
myjeeplovesmud is offline
post #2 of 9 Old 10-15-2009, 05:31 PM
cmonson
what is the code?
cmonson is offline
post #3 of 9 Old 10-15-2009, 05:32 PM
01Limited45324
01Limited45324's Avatar
What's the code? I did a Gumout 2 Step in mine and now I'm getting P0456 (Small Evap Leak).
-Tom
2001 Grand Cherokee Limited
2002 BMW 530i
01Limited45324 is offline
post #4 of 9 Old 10-15-2009, 05:33 PM
Zembonez
Zembonez's Avatar
O2 sensor may be full O crap now. I've had to pull them and do the old intake cleaner spray to remove deposits and junk before. It's successful sometimes. Do not use carburetor cleaner. It can erode the coating in the sensor.
Zembonez - XJ ADDICT -
Originally Posted by Cowboy Cadillac
Canada has 4 seasons...Almost winter, winter, still winter and road construction
Zembonez is offline
post #5 of 9 Old 10-15-2009, 05:39 PM Thread Starter
myjeeplovesmud
i'm not getting a code, that's just it
November 2010 GCOTM
post #6 of 9 Old 10-15-2009, 05:50 PM
vansskaterfreek
probably a missfire code, disconnect the battery for like a minute and that should reset it
1998 ZJ 5.9L 122k miles - DD, 242 swap, 3.5" RE, 32" BFG M/T, safari rack, roof-mounted lights, custom steel front bumper with hitch reciever, 10k winch :)
2004 WJ 4.7L 107k miles - her daily driver, 2" daystar BB with scorpion shocks.. not too bad! stuffed 265/65/17 General Grabber AT2'S
vansskaterfreek is offline
post #7 of 9 Old 10-15-2009, 05:57 PM
cmonson
if your check engine light is on, you should have a code.
cmonson is offline
post #8 of 9 Old 10-15-2009, 09:53 PM
chekk
I had this too the first time I used Seafoam in the Jeep and the light was gone the next day or so.
Software language filtering is dumb
chekk is offline
post #9 of 9 Old 10-16-2009, 09:00 AM
Double E
Double E's Avatar
Check engine light is on = code present
Check engine light flashing = misfire = code may also be present
Was it flashing or on steady?
Check codes by going to wjjeeps.com and reading about codes.
"We have it totally under control. Itís one person coming in from China. We have it under control. Itís going to be just fine." ~D. Trump, Jan 22, 2020.
Double E is offline
Check Engine Light On: 1995 Jeep Grand Cherokee Limited 4x4 4.0 Engine Keith1975 ZJ Grand Cherokee Forum 7 11-04-2014 10:31 PM
Check engine light and ways to check codes cody11ca ZJ Grand Cherokee Forum 12 01-11-2011 09:04 PM
Power Washed Engine - Check Engine Light on Now Davis87YJ ZJ Grand Cherokee Forum 31 08-11-2008 09:17 AM
0 oil pressure and no check engine light? Also what trigers major check engine fault SPL Tech ZJ Grand Cherokee Forum 9 01-08-2007 08:28 AM
check engine light, engine losing power kemicalburns ZJ Grand Cherokee Forum 21 05-27-2005 02:49 PM
