Just bought a 98 Limited; some questions - JeepForum.com
post #1 of 13 Old 07-20-2021, 08:24 PM Thread Starter
ppk487
Hey guys, just bought a 98 Limited 5.2L with 155k miles today for $1500. Runs fine, ac needs work. I plan to bring it to my mechanic this week for a tune up. Only thing I’m concerned with is rusting in the right side rocker panel. Underneath the frame looks to be what you’d expect for a 23 year old vehicle. Anyway, here’s a picture. I don’t mess with welding but I’m wondering if it’s worth having it fixed. Thanks.
ppk487 is offline
post #2 of 13 Old 07-20-2021, 10:03 PM
PolkaPower
PolkaPower's Avatar
Start cutting it out and see how much there is.
Sent from my iPhone using Tapatalk
PolkaPower is offline
post #3 of 13 Old 07-20-2021, 11:56 PM
JonMopar
If that’s the extent of the rust (the rocker panel), then it’s absolutely worth keeping.
98 Laredo ZJ 4L -3.73, 5.9 "ultrastar" rims, slotted brakes, Dynomax turbo, CAI.
JonMopar is online now
post #4 of 13 Old 07-21-2021, 02:37 AM
Timo_90xj
Timo_90xj's Avatar
That rust is definitely way deeper than just rocker, you can see it in the floor pan/ bottom of pillar area as well. You will only see it once you cut open the rockers and see what's there. I wouldn't be surprised to find a lot more rust here and there.
As for is it worth keeping, yes if that is all the heavier rust there is in the lower unibody/ uniframe.
***Under construction***
Timo_90xj is offline
post #5 of 13 Old 07-21-2021, 03:52 AM
Mark-318-IT
as other guys said, start cutting and try to find out what's under that...
360swapped:np242swap,shift kit,BOLT ONs,ome HD coils,aussie locker,dana30hp trussed
Mark-318-IT is offline
post #6 of 13 Old 07-21-2021, 08:14 AM Thread Starter
ppk487
Underneath I don’t think the frame looks that bad but I’m getting it looked at by a very popular Jeep custom shop pretty local that does everything from oil changes to restoring jeeps. Here’s some more pics. The last two pics are right by that rusted rocker panel. That’s the worst area or the undercarriage
9597FF7B-C873-4608-B54C-F76D3706B243_1626876747228.jpg   0698239A-DAE2-4D13-BDA7-AD129C19ED3B_1626876764106.jpg   7E4181C8-E264-41C0-AA8B-186463C32CFB_1626876793789.jpg   3661D9D7-5D11-428B-B751-EBF745081AD4_1626876809333.jpg
ppk487 is offline
post #7 of 13 Old 07-21-2021, 08:15 AM
Mr. Puddles
Follow the build!
2002 Dakota aka Winnie aka Mad Max
1996 Grand Cherokee aka Puddles aka Pikey Life
Originally Posted by kg6mov View Post
The 4.0 is dumb old tractor motor, itís too stupid to know itís supposed to die.
Mr. Puddles is offline
post #8 of 13 Old 07-21-2021, 09:27 AM
Timo_90xj
Timo_90xj's Avatar
Originally Posted by ppk487 View Post
Underneath I donít think the frame looks that bad
Hereís some more pics. The last two pics are right by that rusted rocker panel. Thatís the worst area or the undercarriage
The passenger side lower control arm bracket rear brace is held to the uniframe by rust and it sort of looks like it's partially cracked - or it could be loose rust. Kinda hard to tell from the pictures with all the rust I highly suggest wire wheeling that area, but it's more than like it needs some work (cutting off rusty metal, welding in new).
As for the rockers, as mentioned above the smartest thing to do is to cut off current rockers and weld in box steel rockers. 2" x 6" box steel, 1/8" or 3/16" wall is enough for 95% of people, 1/4" wall is the heavy duty way.
post #9 of 13 Old 07-21-2021, 11:22 AM Thread Starter
ppk487
I have a metal sanding wheel, I’ll have to go pick up a wire wheel I thought I had one. Took off a decent amount of surface rust on the frame. Looks cleaner just me using it about 5 minutes. I’ll go more thoroughly with a wire wheel when I grab one and I’ll hit the under carriage with some rust restorer. My concern is this spot in the frame clearly needs some welded steel. Waiting to hear back from the shop where I want to get a quote but I figure this will need some metal.
ppk487 is offline
post #10 of 13 Old 07-23-2021, 02:12 PM Thread Starter
ppk487
Just picked it up from my mechanic. He said the front axel is rusting out. Will need replacement as well as the ball joints. He’s working up a price for me when I bring it back next week. He also said the exhaust has a leak and that will need to be fixed as well. I’m wondering how worth it this all is for this Jeep (only meant to be a work beater). Thoughts ?
ppk487 is offline
post #11 of 13 Old 07-23-2021, 04:12 PM
PolkaPower
PolkaPower's Avatar
Just picked it up from my mechanic. He said the front axel is rusting out. Will need replacement as well as the ball joints. Heís working up a price for me when I bring it back next week. He also said the exhaust has a leak and that will need to be fixed as well. Iím wondering how worth it this all is for this Jeep (only meant to be a work beater). Thoughts ?
Junkyard axles are like 150 bucks. If you do the work yourself it won't be bad.
post #12 of 13 Old 07-23-2021, 10:19 PM
JonMopar
Have pics of the entire Jeep?
post #13 of 13 Old 07-23-2021, 11:46 PM Thread Starter
ppk487
I’ll have to take more exterior photos but here is one of its good side. Other side has the rot/rust on the front of the rocker panel. The front passenger side undercarriage has the most rusted areas as well.
ppk487 is offline
