JL rubicon rims on a ZJ? - JeepForum.com
 1Likes
  • 1 Post By JR009579
post #1 of 6 Old 07-05-2020, 06:30 PM Thread Starter
JR009579
I have a 95' zj, and i recently purchased a full set of 5 rubicon rims off of a jl. I also have a full set of lug adapters from rough country. I am wondering what kind of a lift i need to fit these tires with the adapters under my zj?
JR009579 is offline
post #2 of 6 Old 07-05-2020, 08:51 PM
jeepjeepster
Depends on the size of the tires....
Whats the BS on those rims and how thick are your adaptors?
1994 ZJ-I6 w/270,000 mi
1998 ZJ 5.9 w/66,000 mi Slate Black
2004 KJ w/108,000 mi
jeepjeepster is offline
post #3 of 6 Old 07-06-2020, 09:01 PM
kg6mov
Hears the voices
kg6mov's Avatar
IIRC the stock JL rubber is around 32ish, generally going to need 2" or better for that.
kg6mov is online now
post #4 of 6 Old 07-06-2020, 10:44 PM
Timo_90xj
Timo_90xj's Avatar
JL Rubicon tires are 285/70 R17, so in the real world they're slightly larger diameter than most 33" x 12.50" tires.
On a ZJ, that equals to needing about 3" of lift and adding ~2"-3" of bumpstop length to make the tires fit and have enough uptravel. Wheel backspacing needs to be roughly 4".
***Under construction***
Timo_90xj is offline
post #5 of 6 Old 07-06-2020, 11:24 PM Thread Starter
JR009579
Sorry for the late response! The tires are ~32". I had seen a previous post on another forum that detailed the lift needed for what size tire, but i knew i would need a larger lift because of the spacers and didnt know how to figure that out. Thanks everyone.
JR009579 is offline
post #6 of 6 Old 07-07-2020, 07:31 AM Thread Starter
JR009579
Tires are 32" with 255/75 17R bf goodrich mud terrains.
Adapters are 1.5 inches thick
LittleFootZJ likes this.
JR009579 is offline
