jk wheels - JeepForum.com
post #1 of 8 Old 04-11-2021, 08:40 AM Thread Starter
97jeepxj1
jk wheels
What are you guys using adapter wise to run jk wheels? I was thinking these
https://www.amazon.com/Ryin-adapters...NsaWNrPXRydWU=
97jeepxj1 is offline
post #2 of 8 Old 04-11-2021, 01:37 PM
yjsaabman
1930 CJ2
I picked up my set off ebay, but the studs seem a bit crappy. Or maybe it's the cheap lug nuts, but I've had a couple gaul up and break. Otherwise they fit great and are hub centric to the ZJ and the wheels, so the fit is really good. A 1.25" thick adapter put a 265/70R17 nice and flush with stock fenders. They do rub the lower control arms at full lock, though.
Sent from my SM-G970U using Tapatalk
yjsaabman is offline
post #3 of 8 Old 04-11-2021, 05:57 PM
CatSplat
CatSplat's Avatar
1994 ZJ
I've been using the Spidertrax hub-centric adapters for a lot of years and they've worked just fine.
1994 5.9L ZJ | IRO 5.5" CPLA | NP242 | 33" Cooper Discoverer STT Pro
The Jeep of Theseus
CatSplat is offline
post #4 of 8 Old 04-11-2021, 07:32 PM
PolkaPower
PolkaPower's Avatar
I've never had problems with Spider Trax. I've used them since early 2000s on three ZJs.
Sent from my iPhone using Tapatalk
PolkaPower is offline
post #5 of 8 Old 04-11-2021, 09:20 PM
chimpanzee
The JK 17x7.5 rims have 6.25" BS, so a 2" adapter/spacer would make an equivalent 4.25" BS..pretty close to the preferred 3.75" - 4" BS of aftermarket 15" wheels. (NOTE: ZJ 15x7 stock rims have 5.25" BS)
I have Titan 2" spacer/adapters:
https://www.ebay.com/itm/4x-2-Hubcen...sAAOSw05JfvsY8
Reviews here:
https://www.amazon.com/Wheel-Adapter...rb_top?ie=UTF8
You need longer wheel studs:
https://www.ebay.com/itm/351772160632
chimpanzee is offline
post #6 of 8 Old 04-12-2021, 11:31 AM Thread Starter
97jeepxj1
went with rough countrys adapters since i had used their spacers before in the past. They are 1.5" thick so will see how it comes out. May go wider if need be
post #7 of 8 Old 04-17-2021, 08:17 AM Thread Starter
97jeepxj1
I've never replaced studs but isn't the knurling/shoulder on those bolts to short for the front? I thought the fronts had a longer shoulder
http://www.ebay.com/itm/4x-2-Hubcent...sAAOSw05JfvsY8
Reviews here:
http://www.amazon.com/Wheel-Adapters...rb_top?ie=UTF8
http://www.ebay.com/itm/351772160632
post #8 of 8 Old 04-17-2021, 08:39 PM
riiz
riiz's Avatar
Those dorman wheel studs work for both ends, shoulders are the same length, but the rear has longer knurling.
riiz is online now
