Jeep slowly cranks when engine is hot - JeepForum.com
post #1 of 4 Old 07-15-2020, 06:14 AM Thread Starter
delmanciomio
delmanciomio's Avatar
Hello,
97 5.2 ZJ has new problem at this hot days
Its starts fine when cold but after driving and engine bay is hot, trying to start my jeep and cranks very very slowly almost i'm out of battery charge.
It starts at least but this noise is very slowly and makes me think it wont start!
Gruuuuuup-gruuuuuup-gruuuuup-gruuuuuuuuuuuuuup then vroom
I check battery voltage gauge almost drops zero while cranking
Battery, cables and all very hot to touch
I have Varta battery 780CCA
What causes this problem
thank you
delmanciomio is offline
post #2 of 4 Old 07-15-2020, 07:46 AM
LordHobbit
LordHobbit's Avatar
battery is probably toast. Use a battery tester when it is cold and then again when it is hot. If it tests bad at either of those times replace it.
93 red ZJ 196k 4.0. Spent more money than I should have ...
LordHobbit is offline
post #3 of 4 Old 07-15-2020, 08:30 PM
RedBolide
It sounds more like heat soak to me. I'd definitely get the battery checked (most auto part places will do it for free) and check to make sure your terminals aren't super corroded. If neither of those things are the culprit, the problem is likely your starter getting too dang hot.
'03 Wrangler Sport / '98 Grand Cherokee Laredo / '90 Comanche Eliminator
RedBolide is offline
post #4 of 4 Old 07-15-2020, 09:59 PM
jeepjeepster
If youre confident in the battery and wiring, get the starter rebuilt.
1994 ZJ-I6 w/270,000 mi
1998 ZJ 5.9 w/66,000 mi Slate Black
2004 KJ w/108,000 mi
jeepjeepster is offline
