Jeep 5.9L Driveshaft U-Joints - JeepForum.com
post #1 of 9 Old 09-25-2018, 01:33 PM Thread Starter
Sandy97ZJ
I cannot seem to find a clear answer on the u-joints required for a stock 5.9L F&R diveshafts.
Can I get confirmation on the number and model numbers below:
Front drive shaft (2 x Spicer 1310)
1. Transfer Case to Front Drive Shaft
2. Front Drive Shaft to Front Diff
Rear Drive Shaft (2x Spicer 1330)
1. Rear Slip Yoke to Rear Drive Shaft
2. Rear Drive Shaft to Rear Diff
So four total? I've seen people say 5 but I can't find the fifth.
Sandy97ZJ is offline
post #2 of 9 Old 09-25-2018, 01:39 PM
kg6mov
Hears the voices
kg6mov's Avatar
The two you need to replace on the front shaft are both at the t-case end in the double cardan.
The fifth would be the one at the front axle. Niner’s didnt have a u-joint there though from the factory, they got the rzeppa CV.
kg6mov is offline
post #3 of 9 Old 09-25-2018, 01:49 PM Thread Starter
Sandy97ZJ
The fifth would be the one at the front axle. Ninerís didnt have a u-joint there though from the factory, they got the rzeppa CV.
Got it. Thank you. Both u-joints in the double cardan are the same?
post #4 of 9 Old 09-25-2018, 02:20 PM
Timo_90xj
Timo_90xj's Avatar
Yeap, front DS two 1310s, rear two 1330s. If rebuilding front DS, get the centering ball yoke as well.
***Under construction***
Timo_90xj is offline
post #5 of 9 Old 09-25-2018, 02:24 PM Thread Starter
Sandy97ZJ
Thank you both for the insight!
post #6 of 9 Old 09-26-2018, 02:15 PM
MrRoundel
Enter your vehicle info into the included utility, and reference the diagram and required u-joints. I know that you already have the info, but this should verify, and serve as good reference in the future. Good luck.
http://www2.dana.com/expertforms/dek350.aspx
1998 Laredo 4.0L 4x4, 242 TC. Turned over 200K miles in 06/18. Original owner.
MrRoundel is offline
post #7 of 9 Old 09-27-2018, 09:22 AM
Mr. Puddles
Knowing I have to do mine in the not too distant future where does one find this centering ball yoke?
Follow the build!
2002 Dakota aka Winnie aka Mad Max
1996 Grand Cherokee aka Puddles aka Pikey Life
The 4.0 is dumb old tractor motor, itís too stupid to know itís supposed to die.
Mr. Puddles is offline
post #8 of 9 Old 09-27-2018, 09:41 AM
MrRoundel
Here's where I got mine.
http://www.dennysdriveshaft.com/p230...its_jeep_.html
You can get a rebuild kit for less money (From another supplier anyway. It might be a Moog brand?), but I opted for the new one. I kept the old one for a backup, and may rebuild it down the road. My front DS had the double-cardan joint, rather than the rezeppa style, but it may not make any difference. Verify before buying. Good luck.
post #9 of 9 Old 09-27-2018, 11:32 AM
kg6mov
Hears the voices
kg6mov's Avatar
Centering ball: https://www.amazon.com/dp/B00GAPLVI4
Centering ball seal: https://www.amazon.com/dp/B00GAPL2CO
kg6mov is offline
