Jacking Up Jeep For Track Bar? - JeepForum.com
post #1 of 11 Old 06-17-2014, 03:14 AM Thread Starter
elijahpr
Hi all,
Just wondering if I need to put my Jeep on stands to install my adjustable track bar? What about sway bar links? I've read mized reports. Both are long overdue. I have a garage I can use usually, but right now only my driveway is available to me, and it's all mud. Not a surface I want to use a jack and stands on. Thanks!
1998 Grand Cherokee TSi (5.2, 44re)
3-inch Rough Country Lift
31" BFG Rugged Terrains
elijahpr is offline
post #2 of 11 Old 06-17-2014, 05:15 AM
newfieZJ
newfieZJ's Avatar
Shouldn't need to be on stands or jack . Helper is always nice . One way to get things lined up is push the body side to side , another way is by turning the steering to move the axle . Can be a pain by yourself , or really easy with help .
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #3 of 11 Old 06-17-2014, 05:17 AM
PolkaPower
PolkaPower's Avatar
I just eyeball it every time. I use the steering wheel which moves the body over the axle when the bar is disconnected. Works great.
PolkaPower is offline
post #4 of 11 Old 06-17-2014, 05:36 AM Thread Starter
elijahpr
Thanks for the replies! I figure I'd eyeball it and adjust the bar accordingly. First time doing it so hopefully I can get the axle to center correctly.
Would I be all set doing the sway bar links while its on the ground as well? If I can get it done in one sitting that'd be mint.
elijahpr is offline
post #5 of 11 Old 06-17-2014, 05:44 AM
newfieZJ
newfieZJ's Avatar
What brand track bar ?
newfieZJ is offline
post #6 of 11 Old 06-17-2014, 05:53 AM Thread Starter
elijahpr
IRO double shear adjustable. Bought it off a forum membw
elijahpr is offline
post #7 of 11 Old 06-17-2014, 05:54 AM Thread Starter
elijahpr
IRO double shear adjustable. Bought it off a forum member, and just got a new hardware kit for it last week.
elijahpr is offline
post #8 of 11 Old 06-17-2014, 06:10 AM
PolkaPower
PolkaPower's Avatar
You do not need to put it on jack stands for any of that. It should be on level ground to get proper measurements.
post #9 of 11 Old 06-17-2014, 06:21 AM
newfieZJ
newfieZJ's Avatar
Install the bracket . Measure your wheels as best you can to see where it sits w/o the track bar . Measure the eye to eye for the track bar mounting hole (bracket/axle) . Calculate how much the jeeps body has to move , apply the result to the track bar measurement and adjust accordingly . Install the axle side bolt first , then the bracket side using methods listed above . If you get a equal measurement on both sides first time , congrats , however , expect to need a tweak or two . To confirm both axles are in line , run a stringline around all four tires , make sure the front wheels are straight . The rear axle has a slight toe in so there will be a gap on the front side between the string and tire . This should appear the same on both sides to achieve the correct thrust angle . Any adjustments will off center your steering . With everything lined up by the string , now reset the wheel position , if you got it right , the wheel will remain straight when driving .
Have fun
newfieZJ is offline
post #10 of 11 Old 06-18-2014, 10:19 AM Thread Starter
elijahpr
Sweet, thank for all the replies. Hoping to get this stuff done today finally. Just need to put my roommates car in neutral and let it glide out of the driveway
elijahpr is offline
post #11 of 11 Old 06-18-2014, 02:43 PM Thread Starter
elijahpr
Put on hold cause I can't get the stupid nut loose on the track bar... grrrrr
elijahpr is offline
