Info wanted: Electric cooling fans - JeepForum.com
post #1 of 14 Old 01-07-2015, 08:02 AM Thread Starter
Scrubberguy
Well I have finally got the 97 ZJ working right, knock on wood, and am now on a quest to see if I can squeeze a few more MPG out of a gallon of gas.
Past experience has shown that the fan is a big HP draw and switching to electric fans has netted a better "feel" and a little better MPG.
The question is has anyone here done a swap?
What I am looking for is either a new bolt in replacement or a donor car / truck that is a bolt in.
I've done the complete "re engineering" and honestly I'm looking for the easy way out here if possible.
Scrubberguy is offline
post #2 of 14 Old 01-07-2015, 01:29 PM
SchizophrenicMC
2016 JK Wrangler
There have been numerous different e-fan setups in ZJs, and I don't know of anybody who ultimately kept theirs. Even swapping in the setup from the 5.9 Limited has had mixed results.
It's just like doing an e-fan setup on any other vehicle, only I hear a lot of mess about poor reliability.
I'll say, when I tried an e-fan swap, I used the fan from a WJ, didn't have enough clearance with the water pump, and the fan drew so much power, the Jeep would die if I turned the headlights on while the fan was running. And there's the real rub of it: you won't gain any mpg from running e-fans over a clutch fan. They're still drawing power from the engine, only now they're taking power from the alternator, rather than the water pump pulley. And if your fan clutch is in good shape, the fan won't draw any power at speed.
Signature rules are dumb
SchizophrenicMC is offline
post #3 of 14 Old 01-07-2015, 03:26 PM
jm8881
I have had zero trouble with mine and I live in the desert.
You can read about my swap here: https://www.jeepforum.com/forum/f13/a...s-fan-1530441/
jm8881 is offline
post #4 of 14 Old 01-07-2015, 04:48 PM
SchizophrenicMC
2016 JK Wrangler
I think the primary problems people have run into are with the fan controls. Aftermarket thermostatic controls are incredibly hit-or-miss, and manual switched fans are inconvenient at best. Always-on fans will reduce fuel economy and put stress on the vehicle charging system.
How did you power the fan in your build? I see a 2-speed relay, but how did you switch the relays on and off?
post #5 of 14 Old 01-07-2015, 04:49 PM
kg6mov
Hears the voices
kg6mov's Avatar
I'm not getting rid of my setup anytime soon, but I also have very specific reasons for why I wanted one and the way I use it. It's definitely not a one size fits all swap.
My setup here: https://www.jeepforum.com/forum/f13/n...l#post23637601
kg6mov is offline
post #6 of 14 Old 01-07-2015, 04:58 PM
dean477
Just to clarify because I've heard that argument before. Will I get better MPG's with my fan(not A/c), headlights/fogs, and sound system off? If so, would upgrading alternators help MPG's?
Dean
dean477 is offline
post #7 of 14 Old 01-07-2015, 05:06 PM
kg6mov
Hears the voices
kg6mov's Avatar
Anything but dyno numbers is speculation when it comes to losses/gains moving from mech fan to e-fan.
The theory is that at the very least an efan when off is causing little to no parasitic loss on the engine where a clutch fan would. With a good cooling system and well setup controls this could be a large percentage of driving. It's all about use case.
If you're looking for a bunch of little things to do to free up some ponies/mpgs then this is one, if you're looking for a magic bullet, keep looking and let me know when you find it.
kg6mov is offline
post #8 of 14 Old 01-07-2015, 05:51 PM
SchizophrenicMC
2016 JK Wrangler
Dean
In theory, yes. In practice, not likely.
If your alternator has 150a of current loads being placed on it (for the sake of round numbers) at the 12v of the vehicle's electrical system, the alternator is putting out 1800w of power, which is equal to almost 2.5hp. That assumes no losses to friction or heat. In reality the number may be higher, though mechanical-electrical conversions are generally very efficient.
Of course, making the same assumptions, if the alternator only has 75a of load being drawn, you're only using 900w, or a little over 1hp. In theory, that will cause a difference in fuel economy, but in practice 1hp isn't much on a 200hp engine.
My argument about the fan drawing power is simply to say that: the whatever you use to force air over your radiator will draw power from the engine. Whether you use a clutch, a hydraulic fan, or an electric fan, some of the engine's power will be used to drive the fan.
There are certainly benefits to using an electric fan over a clutch fan. They tend to have a very static draw, and with proper controls can be made to remove draw instantly, whereas a belt-driven fan may have a progressive decoupling action as the fan clutch cools off. Of course, you'll also lose capacity in your electrical system and you'll place additional load on the alternator, which may struggle to keep up with the load placed on it while the fan is running along with other accessories. (Which is why some luxury cars, as well as some models of WJ, use hydraulic fans, which can be decoupled from engine power via solenoid valve, but don't place load on the electrical system)
Of course, if your fan clutch is in good condition, it should cycle quickly enough that the difference will be negligible, beyond the increased rotating mass, which has a negligible effect on a stock motor's performance.
Your setup is also rather different from most e-fan setups, and as you said, it's for very specific reasons.
I, personally, intend to try swapping a different fan clutch and blade assembly. It is known that the 4.0l 2nd-generation Ford Explorer's fan blade and clutch will fit the 5.2 ZJ water pump and fan shroud with minimal modification. That fan is much lighter and more efficient than the ZJ fan, and the clutch it uses decouples more quickly than even the medium-duty Omix-Ada fan (which is itself quicker to decouple than the most common Hayden Cooling Severe Duty fan from the Ram 2500, which parts stores insist is the only clutch for this application). My search for alternatives continues.
post #9 of 14 Old 01-07-2015, 10:54 PM
Capt_Howdy
When I did the e-fan in my 96, I was too looking for the most reliable method. Chrysler got it right with their 5.9 e-fan setup. So I got everything for the swap and wired everything. It all ran great for about 3 weeks at which point only the fan high speed worked. Replaced the motor with the Ford swap and everything was fine for a few more weeks till again only the fan high speed worked which turned out to be the upper hose switch this time. At this point the message was clear that patching old crap is not the way to go. I replaced both hose switches and also replaced both fan relays. 4 years later and no problem since.
Capt_Howdy is offline
post #10 of 14 Old 01-07-2015, 11:28 PM
siguy
i used a ebay fan with a cheap autozone thermo control setup and it works great
siguy is offline
post #11 of 14 Old 01-10-2015, 09:32 AM
OldManTan
I did the taurus fan with the volvo relay....liked it for a couple months and went back to the mechanical fan.
The power draw and chances of shorting out in the middle of nowhere while wheeling finally pushed me to pull it all.
I went with a 4.0 wj fan clutch from autozone since all I can find at the local autoparts stores were heavy and severe duty fan clutches. Tried the severe duty out, the Mack truck sound 100% of the time was beyond annoying. The 99 4.0 wj clutch + 180 deg thermostat keeps my 5.2 right at 210 degrees while wheeling/driving up hwy 330 to lake arrowhead. Driving around town on the weekends (since this is just my old beater/toy) stays @ 190 deg.
Overhead console said 13.2 mpg avg all city/wheeling/steep hwy grades with the electric fan, 12.7 with the new fan clutch.take it as you want, just wasn't the "OMG i am saving gas!" results I was expecting.
Butt dyno felt like it had slightly better acceleration, but no cold hard facts.
just my .02
good luck with whatever way you go.
6.5" Long arm'd front & rear. 35's. 4.56's. detroit up front lsd rear. ready to go
OldManTan is offline
post #12 of 14 Old 01-10-2015, 07:41 PM
Rikoshay
Have had my Ford Contour dual eFan setup for almost a year and haven't had any problems.
I am using the $35 AutoZone controller, but it controls two 70amp relays (taken from donor car) so that all the load goes thru the relays and NOT the controller. Others have complained that the AutoZone controller just won't last, but what do you expect if you run that much amperage thru it.
Had to replace the water pump so went ahead with this swap. Got the shorter XJ water pump from Rock Auto for $20 and a flat pulley from the junkyard for $5.
https://www.jeepforum.com/forum/f13/my-efan-zj-2716746/
Rikoshay is offline
post #13 of 14 Old 01-10-2015, 07:48 PM
Rikoshay
And of course some whiner will jump in with their 2 cents.
Rikoshay is offline
post #14 of 14 Old 01-10-2015, 10:13 PM
chakkuchan
I switched last summer to a 16 1/2" flex fan (32$ at Oreilly's), not the Flex-a-lite brand but some other name, and I love it. I removed the fan shroud during the install and my Jeep actually runs cooler than with the shroud/clutch/fan OEM design. Just a little FYI, if you have the 4.0, every internet site will list the correct Flex-a-lite flex fan as the 19" one, but it hits on the transmission cooling lines even without shroud. Also get the 2" spacer for the Flex-fan while at auto store.
chakkuchan is offline
