Infinity gold head unit replacement - JeepForum.com
 1Likes
post #1 of 18 Old 08-02-2018, 03:29 PM Thread Starter
Michaelbecker
Hello,
I own a 95 Jeep Grand Cherokee limited. It has the infinity gold system in it but the head unit no longer works. I want to replace it with a single din unit. I have purchased the metra wiring harness and dash adapter. I have wired in a car stereo before but it didnít have an amp. Can I just wire in a new head unit? Iíve read the the ohms are different and the amp could fry my head unit. Does anyone know where I can find some accurate info on doing this job? Thanks for the help.
Michaelbecker is offline
post #2 of 18 Old 08-02-2018, 03:34 PM
riverzj
Find a wiring chart for the amp. You have to splice each wire to bypass the amp. The new head unit will power the speakers on its own, not needing the amp. So you will have to splice the wires from the one side of the amp, that goes to the head unit, to the wires on the other side of the amp that go to the speakers, essentially bypassing the amp. Example: Left Rear speaker wire that's coming from the head unit will have to be spliced into left rear speaker that's coming from the speaker
Sent from my iPhone using Tapatalk
riverzj is offline
post #3 of 18 Old 08-02-2018, 04:22 PM
Mr. Puddles
IIRC the gold systems had an amp. As long as the apm is still good just wire in the new headunit. Did that on my moms 01 Durango and that's how my ZJ is. The ohm difference only matters (but only marginally) between the amp and speakers.
2002 Dakota aka Winnie aka Mad Max
1996 Grand Cherokee aka Puddles aka Pikey Life
Originally Posted by kg6mov View Post
The 4.0 is dumb old tractor motor, itís too stupid to know itís supposed to die.
Mr. Puddles is offline
post #4 of 18 Old 08-02-2018, 04:48 PM
kg6mov
Hears the voices
kg6mov's Avatar
You can keep the amp with a new head unit, and it’s a good plan unless you’re doing a full 5 channel amp.
Just wire up the harness as you normally would. Only gotcha is that the infinity amp uses the power antenna wire to sense power, so you want to hook the remote wire on the radio side harness to the power antenna wire on the jeep side.
kg6mov is online now
post #5 of 18 Old 08-03-2018, 12:24 PM Thread Starter
Michaelbecker
Holy smokes, the power antenna is what powers the amp! You just opened up my world. My antenna stopped working properly and grinding a bunch so I pulled it up and pulled the fuse. Thanks for the help everyone.
post #6 of 18 Old 08-03-2018, 12:26 PM Thread Starter
Michaelbecker
Although, if I install a new head unit anyways, the display in mine no longer lights, and I bypass the amp then I donít have to worry about that power. Is that correct? It means Iíll just have to make sure I have power wires running to the head unit.
riverzj likes this.
post #7 of 18 Old 08-03-2018, 12:29 PM
Mr. Puddles
If you bypass the app then yes you no longer worry about that wire but you are adding in a lot more work to wire in the speakers
Sent from my HTC6545LVW using Tapatalk
post #8 of 18 Old 08-03-2018, 01:03 PM Thread Starter
Michaelbecker
I can get an amp bypass harness for my Jeep from a local audio place. If I bypass the amp wonít I be essentially wiring the speakers to the headunit? Unless Iím not understanding how would that make new speakers hard to install?
post #9 of 18 Old 08-03-2018, 01:21 PM
Mr. Puddles
I was unaware of a pre-made bypass harness.
But why bypass it if it's still working?
post #10 of 18 Old 08-03-2018, 01:24 PM
kg6mov
Hears the voices
kg6mov's Avatar
I’d just keep the amp if you can, it’s a really good buffer amp.
The amp bypass harness will just take the speaker outs from your head unit and link them to the speakers.
post #11 of 18 Old 08-05-2018, 01:59 PM
riverzj
Correct
riverzj is offline
post #12 of 18 Old 08-06-2018, 08:33 AM Thread Starter
Michaelbecker
Thanks for being a helpful group I greatly appreciate it down here in Canada.
post #13 of 18 Old 08-06-2018, 12:13 PM
ricklin
So the amp does not power up if the antenna can't raise? Pls. let me know.
ricklin is offline
post #14 of 18 Old 08-07-2018, 03:14 PM Thread Starter
Michaelbecker
Thatís my understanding from what people are saying. I have no fuse in my power antenna spot. When I turn on my radio it works for about 5 minutes then dies. Iím unsure if thatís because of the lack of fuse or another issue. Hopefully someone will jump in with more accurate info.
post #15 of 18 Old 08-07-2018, 03:48 PM
Mr. Puddles
A power antenna shouldn't keep the radio from functioning. I'd wager that if it works for X time then dies it's probably a thermal issue inside the radio.
Does the radio ever power back up on its own?
