Inexpensive lift advice? 2-4 inch on a 94 Grand Cherokee - JeepForum.com
post #1 of 13 Old 04-26-2015, 08:38 PM Thread Starter
Merc8
1994 ZJ
I have a 94 Grand Cherokee Laredo, 4.0 in line 6, standard tranny. I want to give it a bit of height, but unfortunately I am on the ol "student budget" so the money is a bit tight.
Is there any advice out there for a cheap lift? Preferably between 2"-4"?Performance is not a huge concern, I don't do a ton of off-roading, just here and there. It is mostly for the looks, and I just want to get it a bit higher off the ground. Any advice?
Merc8 is offline
post #2 of 13 Old 04-27-2015, 12:09 AM
green98ZJ
There's lots of info in the FAQs thread that I think you will find very helpful. Go on Amazon and check out jeep zj budget boosts. 2 inch spacers is a good option. Or you can keep saving like I should have!
98 Laredo 4.GO, 373s, Magnaflow, ax15, lifted
green98ZJ is offline
post #3 of 13 Old 04-27-2015, 12:17 AM
moggie99
moggie99's Avatar
Rocky Road's 3.5" lift seems good value - it's what I've just fitted to my ZJ and saves some money by reusing the front springs at the rear.
http://www.rocky-road.com/zj-lift-kit.html
It has a little more roll than with the 2" spacers that I had in there before but the ride is great.
Richard Moss
'98 ZG 5.2L auto ( Austrian built), '96 ZJ 4L auto
In the UK: 1969 MGC GT
moggie99 is offline
post #4 of 13 Old 04-27-2015, 07:47 AM Thread Starter
Merc8
1994 ZJ
Sweet thanks, I'll check it out.
Merc8 is offline
post #5 of 13 Old 04-27-2015, 12:13 PM
CGlaser
dong a F>R swap will save you money, but i suggest saving and going for a full lift kit. The coils you are swapping are the same age as the ZJ, where as your new ones will be stiffer. BB are a good way to go if you dont want a larger lift and you're not doing a lot of offroading.
I used this kit personally. http://zoneoffroad.com/zone-offroad-...p-cherokee/j16
They have a few other options as well. http://zoneoffroad.com/suspension-li...nd-cherokee-zj
Iv had luck dealing with this company, its a sister company To BDS and JKS.
https://www.jeepforum.com/forum/f22/98-zj-slow-build-1484672/
CGlaser is offline
post #6 of 13 Old 04-27-2015, 02:49 PM
kg6mov
Hears the voices
kg6mov's Avatar
Just do a 2" BB until you have time and money to do a real lift.
2" will let you run 31's, the 3.5" f>r stuff will let you run, well, 31's. Do a BB, have fun with it, and then think about where you want to end up and build for that. You can waste a lot of time going from BB, to springs, to taller springs, to all adjustable CA's, to a better axle, to long arms, to a better axle again, etc.
kg6mov is offline
post #7 of 13 Old 04-28-2015, 01:06 AM
cruisingram
I did the Iron Rock off road lift- though I had to go with all new springs- cause mine were shot- still cheaper than buying new stock at local parts store!
Word though-the lift is always higher than it says- your old springs and stuff usually suck, and are sagged down a couple inches, and add 2-4" and you really get closer to 6! I will try post pics tomorrow or next day of my jeep.
cruisingram is offline
post #8 of 13 Old 04-28-2015, 05:44 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Stay away from Rocky road anything for zjs. There pics do not represent RRO products. Use coil spring spacers for a two inch lift. Cheap for very limited budgets. Don't go over and get a three inch spacer...the rear spring likes to spit out.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #9 of 13 Old 04-29-2015, 08:16 PM
cruisingram
Here is a before and after of my jeep using the rather inexpensive IRO kit- I did have to buy both sets of springs however.
post #10 of 13 Old 04-29-2015, 10:46 PM Thread Starter
Merc8
1994 ZJ
Hunter
Where abouts can I find the right coil spring spacers? Also how much $$ are we talking?
Also I don't want DW, so from an installation standpoint, are there any other things I need to do when installing these to make sure nothing goes south on my Jeep?
Merc8 is offline
post #11 of 13 Old 04-30-2015, 01:24 AM
cruisingram
Iron Rock also sells the cheaper spacer kit. Not a fan of it really. Not the product- the concept.
post #12 of 13 Old 04-30-2015, 09:58 AM
kg6mov
Hears the voices
kg6mov's Avatar
If your control arms are original or not recently replaced you should replace all four fronts.
I'd PM Kolak, he can set you up with spacers and good shocks and get you anything else you might need. I suggest going straight to an IRO Double shear track bar up front.
kg6mov is offline
post #13 of 13 Old 04-30-2015, 04:41 PM
rburrow87
rburrow87's Avatar
Yes, definitely hit up Kolak ([email protected]). Especially since you're trying to keep the cost down. He's a vendor for a lot of different companies, including IRO, and will most likely beat everyone else's prices while helping you pick out the right stuff so you'll be happy with what you do.
Bout the only way to go cheaper is if you can manage to buy a used lift. Could try to keep an eye out for anyone selling off their old 1.75-2.25" lift because that's low enough where you can get away with stock components without too much trouble. Beyond that, you're flirting with replacing stuff like track bars, shocks, control arms, sway bar links... etc. Although you may need to change some of those parts already just due to age, so keep that in mind. Could be better off to save up and kill a few birds with one stone by getting a more expensive lift that replaces most or all of those parts.
rburrow87 is offline
1994 zj , cheap , lift + spacers , lift advice
