Idle issues, stumped........ Misfire p0303 - Page 2 - JeepForum.com
post #16 of 30 Old 01-16-2015, 05:37 PM Thread Starter
Nackl87
So I just may have made a breakthrough! I was screwing around with the jeep today, and noticed it was in one of its good moods. Was idling real nice in the driveway, so im like ' hmmm, seems good, im gonna take it for a spin!'..
Well its good for a few mins, than goes back to crap.. Only thing is, this time I noticed the air bag light went on.. I have also previously noticed that the horn intermittently works, but never mentioned it, as it didn't seem important..
So I think I have a bad clockspring, which I have read can affect idle because it shares a common ground with the tps.. Sound reasonable?
Nackl87 is offline
post #17 of 30 Old 01-18-2015, 09:07 AM Thread Starter
Nackl87
Alright, scratch that last idea about the clockspring, another strike.. Turns out I had a loose connector @ the steering wheel but even with it disconnected, no change... After looking at it I don't think the ZJ is the same design as the TJ or XJ...
Nackl87 is offline
post #18 of 30 Old 01-18-2015, 09:57 AM
Scrubberguy
The Noid light is a good idea, you may have a connection or short in the harness for #3 injector.
Should the noid show good to all injectors I'd pull the distributor, after find a shop that can test it, and have them check it out.
This could be as simple as a bad bearing or bent shaft and have the coil checked or replaced as well.
The ZJ's do not take well to electrical issues, mine had a different coil connector spliced into the harness wit solderless butt connectors and it drove me nuts with stalling issues until I stumbled onto the connectors.
wire on the spliced plug wire two different gauges as well, one was 14 the other 22! The JY replacement I aquirred was 14 gauge on both side and had matching color code on the wires.
I soldered the connector in and stalling went away!
My guess is you have an electrical issue, start with the noid and then search your harness then do the distributor.
Scrubberguy is offline
post #19 of 30 Old 01-19-2015, 09:31 AM Thread Starter
Nackl87
Hey scrubber, I def agree at this point that it is an electrical issue.. I drove it all day yesterday and it was in a "good mood" all day.. Didn't get the rough idle once..
I don't understand the concept of how the distributor could really be a culprit though.. A bad bearing causing enough mechanical resistance to slightly throw the timing off?
I fully intend to do the noid test and vacuum test soon, just been busy..
Nackl87 is offline
post #20 of 30 Old 01-20-2015, 05:17 PM Thread Starter
Nackl87
Alright guys, so today I got a hold of a noid light and tested the injector harness. It is not an issue with that.. All injector plugs were acting the same and working fine... The jeep was misfiring the whole time I was testing too.(was fine when I drove to return the noid to parts store though).
I also pulled the distributor and checked that for any play or tightness of the bearings/bushings, and that checked out fine too. No noticeable wear on the cam gear besides normal gear pattern wear.
I did notice today that there is a noise coming from the motor that is really pronounced when it is missing, but gone or much more quiet when its not missing.. It doesn't sound like its coming from the bottom end, but is more noticeable under the jeep/ passenger side. It also doesn't really sound like it is consistent with rpm, more lopey..
I just did a little research about sticky lifters, and this seems like a real possibility at this point..
Nackl87 is offline
post #21 of 30 Old 01-20-2015, 05:25 PM
ZeeJay1997
https://www.jeepforum.com/forum/f13/h...l#post25262802
ZeeJay1997 is offline
post #22 of 30 Old 01-20-2015, 05:35 PM Thread Starter
Nackl87
Oh no zeejay, what are you suggesting with that link? That I need to rebuild the top end? I sure hope not, if that's the case there will be a zj going up for sale reeeeeal soon.
Is there no merit to adding trans fluid or seafoam in an attempt to 'unstick' a lifter?
Nackl87 is offline
post #23 of 30 Old 01-20-2015, 05:58 PM
ZeeJay1997
you might do some good with an oil additive, but i've never put much faith in those. never really tried one. do a little research on them. there's a lot of them out there, but i've always regarded them as snake oil. maybe someone else has a better idea.
post #24 of 30 Old 01-20-2015, 06:04 PM
ZeeJay1997
use a stethoscope to pinpoint the noise
post #25 of 30 Old 01-20-2015, 06:37 PM
Yardman Harry
O
Yardman Harry's Avatar
I had a similar problem. Ended up being a bundle of wires next to the firewall was resting on a clamp to the ac. After time the clamp rubbed through the wires and was shorting one of them out. I tried everything in the book to fix the code and idle. Finally I was on my way to Florida and I hit a small bump coming out of a rest area... I guess that bump caused another wire to become exposed. And the two shorted out and stalled the jeep and blew the starter fuse.
Anyway... Fixed the wires and everything went back to normal.
Another time I threw a code for cylinder misfire the heater hose into the firewall was resting on the injector wire. Caused a short and the wire was barely exposed.
Just something to look for. Good luck.
Yardman Harry is offline
post #26 of 30 Old 01-30-2015, 06:36 AM Thread Starter
Nackl87
I just wanted to update this, out of respect for those who took the time to respond.
As of now I have pulled the head off the jeep and am taking it in to get a valve job done ( the offending #3 cylinder,as well as #2 intake valves are not seating fully)..
I also replaced the lifters, water pump and some other misc parts when I have the motor ripped this far apart..
I will update again when I get the whole thing back together.
Nackl87 is offline
post #27 of 30 Old 01-30-2015, 09:09 AM
MrRoundel
Out of curiosity, when did you realize that you had to pull the head? Did you do a vacuum test, and it showed instability? Compression test? Thanks. Sorry you had to go the radical route. Good luck with the repair.
MrRoundel is offline
post #28 of 30 Old 02-01-2015, 09:10 AM Thread Starter
Nackl87
Solved!!
I almost don't want to admit this, after doing so much trouble shooting and unnecessary work.
It turns out that the Upstream o2 sensor wiring was fried by my exhaust.. I am really quite surprised that it wasn't throwing any codes..
I think that the wiring was the main issue, but I did also have 2 leaky intake valves ( I'm not sure how big a deal that would have been if I would have found the wiring first).
So, jeep basically has a new top end, new water pump etc, Runs GREAT!!
I really appreciate all the input from everyone.
Nackl87 is offline
post #29 of 30 Old 02-01-2015, 10:20 AM
ZeeJay1997
Dont feel bad. It happens all the time. People get lulled into a false sense of security because they think the PCM is some kind of magic device that will automatically tell them what's wrong with the vehicle. News flash... It's not.
Now that it's running great, take time to look it over and be sure there are no similar situations where the wiring can be damaged. It sounds like the wire harness was misrouted or missing a clamp because the OEM location wont allow the harness to contact the manifold.
I really thought I had included this in the article I wrote, but I didnt find it, so I made an edit to include this particular location to check. It's not the first time it's happened and probably not the last.
Glad you got it fixed.
post #30 of 30 Old 02-01-2015, 01:38 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
...and If you ever have anyone work on anything that involves wiring check behind them. I lost a pcm once due to a shop installed rear 02. When my exhaust was installed they left the front 02 connector off the bracket.
Originally Posted by HighLonesome
coralman is offline
idle , jeep , rough
