I need a good screw....molding screws that is... - JeepForum.com
post #1 of 12 Old 09-21-2020, 03:55 PM Thread Starter
Rapidrob
Rapidrob's Avatar
What are you members using to replace missing molding screws? I need the 3/4" and the longer 3" black "wood screw" large head type screws to remount the molding which was not maintained by the original owner.
I'd like to buy them in bulk or by the tens if I can.
Rapidrob is offline
post #2 of 12 Old 09-21-2020, 05:32 PM
Tomcorr
I went to a place called Fredís Nuts and Bolts he had what I needed just gave him one of each and he brought them out.
Unless your in CG Arizona it doesnít do you much good.
But the point is I would of never dreamed they had that stuff, the guy at the Dealership actually sent me there.
So maybe where you live you can ask the dealership there where you might get them.
Also check your ACE Hardware stores they are starting to carry more screws and bolts. Heck they carry gun screws out here now.
95 Grand Cherokee Laredo
Tomcorr is offline
post #3 of 12 Old 09-21-2020, 07:57 PM
kg6mov
Hears the voices
kg6mov's Avatar
I'm a fan of https://www.auveco.com for little bits like screws and interior hardware if I'm trying to stay factory. Catalog can be a bit of a bear to dig through though.
kg6mov is offline
post #4 of 12 Old 09-21-2020, 08:16 PM
At1bob
At1bob's Avatar
Sometimes I use silver screws and black spray paint. The key is to let the paint dry before you pick them up. Lol
Sent from my SM-G930V using Tapatalk
At1bob is offline
post #5 of 12 Old 09-21-2020, 08:49 PM
zjosh93
My first stop for bits like that is Clips and Fasteners. But now that I look closer they mostly sell the Auveco stuff kg6mov linked to.
zjosh93 is offline
post #6 of 12 Old 09-22-2020, 12:54 AM
Ralph77
Not sure what you are looking for but do you have a Napa near you?
If so if yours is anything like mine they have this big loose leaf binder there.
Has all sorts of stuff like this in it.
Not pictures but the actual piece.
If you have one of the originals then you can see if you can match it up easy enough.
If not a perfect match might be able to find something close that will work.
Better then trying to work off pictures, descriptions, and measurements.
Ralph77 is offline
post #7 of 12 Old 09-22-2020, 07:36 AM
Trons
Locally, I have 2 places. Diamond Screw Products (DSP) and we have a shop that sells pretty much everything you need for body work and interior work. Look around and see if you have either of those?
I will say that DSP only takes cash on small purchases (like under five dollars).
'03 TJ Rubicon (sold)
'16 KL Latitude
'97 Grand Cherokee Laredo, Stock (for now)
Trons is offline
post #8 of 12 Old 09-23-2020, 09:34 AM Thread Starter
Rapidrob
Rapidrob's Avatar
Thanks for the info.
Rapidrob is offline
post #9 of 12 Old 09-24-2020, 03:42 PM
speedbrake
1994 ZJ
Can't believe no one's mentioned the Junkyard yet. At my local JY there always at least 10 ZJ hulks and you can pretty much find any trim panel screw you need
speedbrake is offline
post #10 of 12 Old 09-24-2020, 03:45 PM Thread Starter
Rapidrob
Rapidrob's Avatar
I went to the Upullit&Pay today, 40 miles away and filled a 1/2 coffee can with Jeep GCL screws from Jeeps going to the crusher for a buck out the door.
Thank you for all the replies,I do appreciate it.
Rapidrob is offline
post #11 of 12 Old 09-24-2020, 06:27 PM
hilljacknm
Dang Rob. Save something for the rest of us.
Forgot to mention, there was a ZJ there with tow hooks. Dunno if you need them or not.
1996 ZJ 5.2
Doug Thorley Headers, Kolak exhaust
B&M 70268 trans cooler
BFG KM3 30x9.50"
hilljacknm is offline
post #12 of 12 Old 09-24-2020, 09:05 PM Thread Starter
Rapidrob
Rapidrob's Avatar
I will check that out in the AM, tow hooks would be nice.
'Nam Vet
Tin Can Sailor
President
NM MILSURPS
Rapidrob is offline
