HVAC Foam Seals - JeepForum.com
post #1 of 7 Old 06-02-2020, 09:22 PM Thread Starter
Some_Anchovies
Some_Anchovies's Avatar
HVAC Foam Seals
I've been searching for replacement seals for the ZJ as I am replacing the evap core and the heater core, but I've been having some trouble finding good information on the seals. The oem seals are obviously not offered anymore and I can't find aftermarket ones, so I am going to replace the seals with something commonly found from the hardware store. I don't want to do it over again later, so I'm going to replace everything, including the blend and recirc door foam. I've found threads where people have replaced the seals while in replacing the box, but they don't mention what sizes they used. If anyone has done the seals before and remembers what they used, I'm all ears. Otherwise, I'm planning on trying to find some 1/4" open cell foam for the doors and some other seals for everything else.
95' ZJ 4.0L, 5-Speed Swap, NP231, 282k
Ex-Master Mechanic-turned-Software Developer
Some_Anchovies is offline
post #2 of 7 Old 06-03-2020, 07:41 AM
LittleFootZJ
I used various thickness of foam from Home Depot for home HVAC. I think the company was Frost King? I may have pictures buried in my phone of the packaging...let me check
Sent from my iPhone using Tapatalk
LittleFootZJ is offline
post #3 of 7 Old 06-03-2020, 07:47 AM
LittleFootZJ
HVAC Foam Seals
This is the stuff. But this was the largest I bought. I also used 1/4” and 1/8” I believe. Just kind of had to make an educated guess on the thicknesses. Look at the parts it’s attempting to seal and use the thickness that makes most sense. As long as the doors move freely when you’re done than it will be fine. I went overboard on the recirc door and had to redo it because it needed to be a little thinner on the edges to fold properly.
post #4 of 7 Old 06-03-2020, 02:52 PM
1996maroonzjf
1996maroonzjf's Avatar
I did the same as posted above. I bought packages of a few sizes and just made the call as necessary depending on the existing sizes. I got 1/8”, 1/4”, and 3/8”.
Be cautious the adhesive is not great on the stuff and is not intended to be used in high heat applications. The heat from the heater core and or sun on a hot day can be pretty intense. I had a pice of the 3/8” come loose and get caught in the fins on the blower motor - killing the motor. It was a 23 year old fan so it may be a coincidence or the needle that broke the camels back, but I could hear the weather stripping hitting / jamming up the fan and I had to rip a section off when I R&R’d the fan.
-Tim
(2) '96 4.0s
#1-'10-'18
#2- HP30/Ford 8.8 - 4.56, OME HDs, 5100's, IRO Adj Arms/Track Bars
1996maroonzjf is offline
post #5 of 7 Old 06-03-2020, 07:02 PM
LittleFootZJ
I should add I also scuffed up the plastic with a scotch brite pad and added 3M spray adhesive to the back of them so that wouldn’t happen. The high strength stuff you would use for headliner or something is what I used because I had it laying around. The adhesive on them is really no good by itself.
post #6 of 7 Old 06-03-2020, 07:53 PM
jeepjeepster
I went to lowes, ace hardware, and walmart and just bought whatever foam they had. I might have made a thread around here somewhere. Used permatex spray adhesive on everything, stuff seems to work great.
1994 ZJ-I6 w/270,000 mi
1998 ZJ 5.9 w/66,000 mi Slate Black
2004 KJ w/108,000 mi
jeepjeepster is offline
post #7 of 7 Old 06-10-2020, 12:11 PM Thread Starter
Some_Anchovies
Thanks for the suggestions everyone. I'll grab 3 sizes and just go with what works.
hvac , seal
