How do I make this Rubicon Engineering SYE 242, a non SYE? - JeepForum.com
post #1 of 12 Old 03-28-2020, 07:54 PM Thread Starter
8v-of-fury
So, the case itself was a good price and I need one BADLY. However it does have the SYE installed that doesnt work for me as I dont have that style of driveshaft.. nor do I require one. The 2" puck lift is all that I need out of this Jeep.
IT LOOKS like I will unbolt that "tail housing" from both and just swap the entire situation between the two cases eh??
As can be seen, my old case has had her day! If you grab the front shaft. And move its slack back and forth (there is a lot of it), you can slap the chain against the top and bottom of the case haha. And it is leaking every drop of fluid it has, and slinging it all over floorboard.
Resized_20200327_011625_1585446763245.jpeg   20200328_214858_1585446775594.jpg
'98 ZJ 4.0/242, Locked d30/d35, 31x10.5x15, 2" BB w/ Bilstein 5100's
8v-of-fury is offline
post #2 of 12 Old 03-28-2020, 08:27 PM
CatSplat
CatSplat's Avatar
1994 ZJ
I think you'll need to swap the mainshaft over from your old case to the new one. There were small changes to the mainshaft design over the years, so whether your old one is a direct install into the new one, I can't say for certain.You won't know for certain until you get both pulled out and inspect them. This requires a complete teardown of both cases.
1994 5.9L ZJ | IRO 5.5" CPLA | NP242 | 33" Cooper Discoverer STT Pro
The Jeep of Theseus
CatSplat is offline
post #3 of 12 Old 03-28-2020, 10:16 PM Thread Starter
8v-of-fury
Both transfer cases are of the same age, 98-99.
So hopefully they are identical. Haha
post #4 of 12 Old 03-28-2020, 11:57 PM
CatSplat
CatSplat's Avatar
1994 ZJ
Probably are! Just have to hope that whatever's wrong with your 242 hasn't hurt the mainshaft - it's likely just the chain though. Mainshafts don't get damaged often unless you snap it.
The Jeep of Theseus
CatSplat is offline
post #5 of 12 Old 03-29-2020, 12:33 AM
Timo_90xj
Timo_90xj's Avatar
Yeah, swap the mainshaft from the old case to the replacement case. Make sure the mainshaft from your original TC doesn't have pitting or (lack of) lubrication- related issues on it.
***Under construction***
Timo_90xj is offline
post #6 of 12 Old 03-29-2020, 10:45 AM
1996maroonzjf
1996maroonzjf's Avatar
Are both cases 231? I seem to remember from you other posts the one installed in your ZJ is a 242.
-Tim
(2) '96 4.0s
#1-'10-'18
#2- HP30/Ford 8.8 - 4.56, OME HDs, 5100's, IRO Adj Arms/Track Bars
1996maroonzjf is offline
post #7 of 12 Old 03-29-2020, 11:44 AM
CatSplat
CatSplat's Avatar
1994 ZJ
They're both 242s.
The Jeep of Theseus
CatSplat is offline
post #8 of 12 Old 03-29-2020, 01:46 PM Thread Starter
8v-of-fury
Yes both 242, other than the SYE they appear identical.
My current 242 has a 97 build tag
This new 242 has a 99 build tag
post #9 of 12 Old 03-29-2020, 08:07 PM
1996maroonzjf
Sorry about that. Carry on -
-Tim
(2) '96 4.0s
#1-'10-'18
post #10 of 12 Old 04-05-2020, 05:46 PM Thread Starter
8v-of-fury
Doesn't appear that my output shaft took any damage, even though the pump ate itself! Haha
Gonna do new output shaft seals and bearings in the new case, but cant seem to find a part number for the output shaft seal for the back of the 42RE.. anyone got a number??
Snapchat-864108197_1586130168466.jpg   20200405_185027_1586130181632.jpg   20200405_185032_1586130192218.jpg   20200405_185421_1586130262938.jpg   received_562469691291508_1586130283736.jpg
post #11 of 12 Old 04-07-2020, 09:32 PM Thread Starter
8v-of-fury
Anyone familiar with the Rubicon Engineering SYE yoke?
How does it stay attached to the rear output shaft? This one had a washer welded on to the end if the shaft that I had to cut off. Lolol.but after removing that, I cant see how it would normally stay on either... there isnt anything to hold the yoke on.
Ps. Good news. My two output shafts are the same, and this un-conversion should work.
post #12 of 12 Old 04-07-2020, 10:04 PM Thread Starter
8v-of-fury
Oooh, I see.. This is the hack'n'tap method of adding a SYE..
I assume they busted off their bolt I nthe end of the output shaft and welded the washer on solid.. haha wow.
