hi im new to forum...i need help - JeepForum.com
post #1 of 18 Old 03-03-2010, 04:34 PM Thread Starter
justjv562
hi im new to this forum....im having problems with my 96 grand cherokee laredo.its a v6...i bought it about three days ago.it has an electrical problem i believe.when i start it up it turns on ok.but about a min later it turns off..then i have to wait about a min to turn it on again.it only does this when the engines temp is still cold.once it warms up its fine to drive.do you guys have an idea what it could be?i appreciate the help.
justjv562 is offline
post #2 of 18 Old 03-03-2010, 05:44 PM
xjokee
Do a search. Could be a fuel delivery problem.
Good luck.
Mike
~ When in doubt........Throttle out! ~
xjokee is offline
post #3 of 18 Old 03-03-2010, 07:10 PM
wickerham
you have an inline 6 btw
wickerham is offline
post #4 of 18 Old 03-03-2010, 07:22 PM
melk
Welcome aboard
How many miles out of curiosity?
Turn the key on (not starting the engine, just to on, then off)
on off on off on
and watch the odometer closely, it will blink and display numerical codes. Write down any that you see and report back here
Also, you could try checking all the fuses and relays. There's a panel on the passengers side under the glove box and also a box in the engine compartment above the battery.
Also, you could try disconnecting the negative (black) terminal on the battery for 10-30 minutes which will 'reboot' the PCM.
melk is offline
post #5 of 18 Old 03-03-2010, 08:21 PM
sdonovan
i had a similar problem in mine. i changed the battery and havent had a problem since
sdonovan is offline
post #6 of 18 Old 03-04-2010, 12:18 AM Thread Starter
justjv562
the guy that sold me the truck said he thinks its the crankshaft position sensor...do you guys think it could be that?im also going to get that code for you guys...i believe it has 226,000 miles on it...i really havent messed with the truck since its at my moms house and i really havent gone out their..to tell you guys the truth i havent even drove it yet.my brother has been driving it...
post #7 of 18 Old 03-06-2010, 05:37 PM Thread Starter
justjv562
so i finally got the codes,they are 12,43,72,14,55....
post #8 of 18 Old 03-08-2010, 04:15 AM
melk
12 means the battery has been disconnected recently, no big deal
55 means the end of the codes
43, 72, 14 I don't know off the top of my head. You can find a list pretty easy though if you google it. It's also listed in a Haynes manual which is well worth the $20.
It _could_ be the crankshaft position sensor like your brother thinks, as this is a pretty common cause of the crank-no-start situation. I actually had the same problem when I first got my ZJ (96) about six months ago -- came here to ask for advice and was told crankshaft position sensor... took it to the mechanic and yep that was it, replaced it and I haven't had any trouble since.
melk is offline
post #9 of 18 Old 03-08-2010, 04:57 AM
newfieZJ
newfieZJ's Avatar
14 : MAP sensor voltage too low /high /or 5 Volt output to MAP sensor open . A OBDII code reader would tell you exactly which one
43 : Multiple misfires , could come from either cylinder . Again , a code reader would be more accurate to pin point the issue . Could be the coil itself
72 : Your cat is operateing at low efficency . You might need a new one .
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #10 of 18 Old 03-08-2010, 03:59 PM Thread Starter
justjv562
thanks...i know i need a new catylic converter because the guy that sold it to me told me it was ruined..and im probably going to change the map sensor and crankshaft position sensor.
post #11 of 18 Old 03-10-2010, 08:50 PM Thread Starter
justjv562
so i changed the crankshaft position sensor thinking it might be only that..well last night my lilttle problem happened again....and today while i was driving to school the jeep turned off on me...it beaped and then it turned off...and when i tried to turn it on it made a weird sound and then it turned off..then i tried to start it again and it turned on.and my engine light hasn't turned on since i reset the truck by disconnecting my negative battery wire...do you guys think its my map sensor?or do you think it could be caused because of my torn muffler?even though that sounds stupid even to me...
post #12 of 18 Old 03-11-2010, 09:14 PM
rooster51
rooster51's Avatar
When you replace the cat you should replace your upstream & downstream O2 sensors also.
Terry
rooster51 is offline
post #13 of 18 Old 03-12-2010, 04:11 PM Thread Starter
justjv562
ok.....so today i was trying to figure out whats wrong with my jeep and i turned it on and it started great but after 20 min on it turned off...and my engine light still hasnt turned on...do you guys think this is happening because i have missfires?
post #14 of 18 Old 03-12-2010, 06:10 PM
rm2001wj
rm2001wj's Avatar
Some times when a cat goes bad, the honeycomb breaks up and clogs the exhaust system. The engine won't run very much if that's the case. I think you should replace the cat first and see what happens. Unfortunately, a cat replacement can be more expensive than the crank sensor and MAP sensor put together.
rm2001wj is offline
post #15 of 18 Old 03-12-2010, 06:34 PM
bucfan1234
I have a 96 ZJ I6, and I just got a recall notice for the Catalytic Converter in the mail today from Chrysler, Dodge Jeep. Kind of crazy 14 years later, but true. In fact I thought it was for my WK, but it was for the ZJ.
When my Cat went out, it was like my engine was vapor locked. It would barely run, no power, stalling, etc. .
Bottom line dont buy a cat converter before you call to have your VIN run over the phone with either the dealer or the 800 number. If your vehicle's VIN is included under the recall, they will replace it for free.
Recall = E22 reprogram PCM and replace Catalytic Converter
Hope this helps.
bucfan1234 is offline
Hello Forum wickednick ZJ Grand Cherokee Forum 8 09-11-2008 01:41 AM
New to the Forum Jarred1991 ZJ Grand Cherokee Forum 7 03-01-2008 09:00 AM
new to the forum K10roc ZJ Grand Cherokee Forum 3 12-10-2007 01:41 PM
New to forum ozzyn ZJ Grand Cherokee Forum 2 09-29-2007 03:41 PM
new to forum?? speedy14850 ZJ Grand Cherokee Forum 1 02-06-2007 11:20 AM
