Hey you WJ Grand Cherokee types who have replaced your front speakers... - JeepForum.com
post #1 of 12 Old 08-23-2007, 04:57 PM Thread Starter
Jerry Bransford
Administrator
Jerry Bransford's Avatar
The passenger-side front speaker in my wife's 2002 WJ has blown. How do you get to it to replace it? Does the defrost vent piece it's underneath just unsnap and it's underneath? I'm an old stereo/audio guy but unless that top piece just unsnaps, it looks like it could be a nightmare replacing that front speaker. I hardly drive it and she's working most weekends (real estate) so when I finally get ahold of it to replace the speaker, I need to make it a fast job so any help here will be much appreciated.
No speaker recommendations are needed, she doesn't listen to much more than the news or talk radio so I'll just install suitable replacement. TIA!
Jerry Bransford is offline
post #2 of 12 Old 08-23-2007, 05:45 PM
skain8
skain8's Avatar
the top of the dash (defrost vent piece) pops off with a putty knife and the speakers are held in with 2 screws. takes less than 5 min.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #3 of 12 Old 08-23-2007, 05:58 PM Thread Starter
Jerry Bransford
Administrator
Oooohhhhh AWESOME, that's great news that I won't have to disassemble the dash! Thanks for your help very much!
post #4 of 12 Old 08-23-2007, 06:03 PM
nierace
nierace's Avatar
2003 WJ
At least not until the blend door goes
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
North East Offroad Club
nierace is offline
post #5 of 12 Old 08-23-2007, 06:16 PM
ras2001wj
ras2001wj's Avatar
Are you just replacing the tweeters or replacing them with a component set? The dash "Tweeters" have a far broader frequency range than standard tweeters (to help with the mid ranges not covered by having a 6x9 in the front doors) and without a new crossover can (and will) damage the replacement tweeters unless they have a built in crossover to cut out the mid range frequencies. If you keep the front 6x9's, you will notice a loss in md ranges which by personal preference may sound too high pitched in the dash and too low pitched in the doors, due to the frequency loss.
best bet is to find a quality 6.5" component set and rewiring them directly to the head unit (amp has built in crossover that pushes the wrong frequency range for the new speakers crossover to handle)
I would go to a reputable audio shop and ask their opinion, they may try and push a $3000 complete audio system off on you, but turn that down and say you only want to find a set of tweeters with a comparable frequency range.
All In all, I'm a perfectionist, so I may get way too complex in this
Good luck,
Rick
2001 WJ Laredo 4.0
2" BB
245/75R16
Ron Paul
2012
"Freedoms Popular"
ras2001wj is offline
post #6 of 12 Old 08-23-2007, 08:09 PM
Two Hawks
A 7mm socket & mini ratchet makes R&R a snap. I took the speakers out and removed the black cloth cover to expose the speaker material and ran a small layer of ultra blue rtv around the perimeter of the speakers edge. Reglued the black cover and they work fairly well, just let the rtv cure for a day and you're go to go.
Two Hawks is offline
post #7 of 12 Old 08-23-2007, 09:50 PM
Briandl
Good luck,
I'm sure that's all necessary for her to listen to talk radio....
2002 Jeep Grand Cherokee Limited 4.7L H.O. V8
Briandl is offline
post #8 of 12 Old 08-24-2007, 07:06 PM
ras2001wj
ras2001wj's Avatar
darn, didn't read the whole post
Rick
2001 WJ Laredo 4.0
2" BB
245/75R16
Ron Paul
2012
"Freedoms Popular"
post #9 of 12 Old 08-24-2007, 07:23 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Playing a tweeter with sub-tweeter frequencies not filtered out will blow the tweeter very fast, and the OP will be replacing tweeters more often than he thought.
If what ras2001wj said is true, I suggest more investigation into a suitable replacement set is in order.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #10 of 12 Old 08-24-2007, 07:45 PM
JG_Canuck
I'm with Two Hawks. Speaker glue on the surrounds FTW!
I did both speakers at a total cost of $5.99 (for the speaker cement) and a time investment of about 20 minutes...
JG_Canuck is offline
post #11 of 12 Old 08-24-2007, 08:24 PM
BucYouUp68
I blew the passenger side, I have the Infinity Preminum Sound System. I replaced both with MB Quart Tweeters with Crossovers. They Sound Awesome, with no issues.
Features
0.75" Titanium tweeter
Separate Crossover
Power Handling: 50 - 100 W
Impedance: 4 ohms
Sensitivity: 1,5 W (90 dB/1m)
Frequency Response: 4.800 - 32.000 Hz
Crossover Frequency: 4.800 Hz
Crossover Slope: 12 dB/octave
Balanced Temperature Technology is used in the tweeter
A light bulb is incorporated into the crossover network to extend the life of the tweeter by protecting it against overloading
Tweeter with a 0.75” titanium dome and an extremely small footprint
Multi-purpose mounting accessories are included
Compatible with all Reference Series speaker systems
$139.00
Why is there a fish finder in your Jeep?
Not hard, if you have a socket wrench and the mental capacity of a ham sandwich.
BucYouUp68 is offline
post #12 of 12 Old 08-24-2007, 08:33 PM Thread Starter
Jerry Bransford
Administrator
What, are you guys saying the cone itself may just be blown?
93 jeep grand cherokee(4.0) radiator needs to be replaced Mustang ZJ Grand Cherokee Forum 11 06-18-2015 12:41 PM
1998 Grand Cherokee - No Spark, Replaced all the Usual Suspects - Any Ideas? kwbunn ZJ Grand Cherokee Forum 4 06-08-2008 09:02 AM
Speakers size for 1996 Grand Cherokee LTD. Jungerishere ZJ Grand Cherokee Forum 1 11-20-2005 08:30 AM
1994 Grand front door speakers wkeil88K5 ZJ Grand Cherokee Forum 0 12-13-2002 08:34 AM
Changing speakers in 98 Grand Cherokee Laredo sgtrahanlsu ZJ Grand Cherokee Forum 3 12-03-2002 03:50 PM
