JeepForum.com (https://www.jeepforum.com/forum/)
-   ZJ Grand Cherokee Forum (https://www.jeepforum.com/forum/f13/)
-   -   Hey you WJ Grand Cherokee types who have replaced your front speakers... (https://www.jeepforum.com/forum/f13/hey-you-wj-grand-cherokee-types-who-have-replaced-your-front-speakers-453626/)
Jerry Bransford 08-23-2007 04:57 PM
The passenger-side front speaker in my wife's 2002 WJ has blown. How do you get to it to replace it? Does the defrost vent piece it's underneath just unsnap and it's underneath? I'm an old stereo/audio guy but unless that top piece just unsnaps, it looks like it could be a nightmare replacing that front speaker. I hardly drive it and she's working most weekends (real estate) so when I finally get ahold of it to replace the speaker, I need to make it a fast job so any help here will be much appreciated.
No speaker recommendations are needed, she doesn't listen to much more than the news or talk radio so I'll just install suitable replacement. TIA! :)
skain8 08-23-2007 05:45 PM
219 Attachment(s)
the top of the dash (defrost vent piece) pops off with a putty knife and the speakers are held in with 2 screws. takes less than 5 min.
Jerry Bransford 08-23-2007 05:58 PM
Oooohhhhh AWESOME, that's great news that I won't have to disassemble the dash! Thanks for your help very much! :thumbsup:
nierace 08-23-2007 06:03 PM
At least not until the blend door goes :p
ras2001wj 08-23-2007 06:16 PM
Are you just replacing the tweeters or replacing them with a component set? The dash "Tweeters" have a far broader frequency range than standard tweeters (to help with the mid ranges not covered by having a 6x9 in the front doors) and without a new crossover can (and will) damage the replacement tweeters unless they have a built in crossover to cut out the mid range frequencies. If you keep the front 6x9's, you will notice a loss in md ranges which by personal preference may sound too high pitched in the dash and too low pitched in the doors, due to the frequency loss.
best bet is to find a quality 6.5" component set and rewiring them directly to the head unit (amp has built in crossover that pushes the wrong frequency range for the new speakers crossover to handle)
I would go to a reputable audio shop and ask their opinion, they may try and push a $3000 complete audio system off on you, but turn that down and say you only want to find a set of tweeters with a comparable frequency range.
All In all, I'm a perfectionist, so I may get way too complex in this
:cheers2: Good luck,
Two Hawks 08-23-2007 08:09 PM
A 7mm socket & mini ratchet makes R&R a snap. I took the speakers out and removed the black cloth cover to expose the speaker material and ran a small layer of ultra blue rtv around the perimeter of the speakers edge. Reglued the black cover and they work fairly well, just let the rtv cure for a day and you're go to go.
Briandl 08-23-2007 09:50 PM
I'm sure that's all necessary for her to listen to talk radio....
:rolleyes:
ras2001wj 08-24-2007 07:06 PM
:rolleyes:
darn, didn't read the whole post
UltimatE 08-24-2007 07:23 PM
:rolleyes:
Playing a tweeter with sub-tweeter frequencies not filtered out will blow the tweeter very fast, and the OP will be replacing tweeters more often than he thought.
If what ras2001wj said is true, I suggest more investigation into a suitable replacement set is in order.
JG_Canuck 08-24-2007 07:45 PM
I'm with Two Hawks. Speaker glue on the surrounds FTW!
I did both speakers at a total cost of $5.99 (for the speaker cement) and a time investment of about 20 minutes...
BucYouUp68 08-24-2007 08:24 PM
I blew the passenger side, I have the Infinity Preminum Sound System. I replaced both with MB Quart Tweeters with Crossovers. They Sound Awesome, with no issues.
http://farm2.static.flickr.com/1337/...c2652542_o.jpg
Features
0.75" Titanium tweeter
Separate Crossover
Power Handling: 50 - 100 W
Impedance: 4 ohms
Sensitivity: 1,5 W (90 dB/1m)
Frequency Response: 4.800 - 32.000 Hz
Crossover Frequency: 4.800 Hz
Crossover Slope: 12 dB/octave
Balanced Temperature Technology is used in the tweeter
A light bulb is incorporated into the crossover network to extend the life of the tweeter by protecting it against overloading
Tweeter with a 0.75” titanium dome and an extremely small footprint
Multi-purpose mounting accessories are included
Compatible with all Reference Series speaker systems
$139.00
Jerry Bransford 08-24-2007 08:33 PM
What, are you guys saying the cone itself may just be blown?
The time now is 01:59 AM.
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
