Help me. Understand - JeepForum.com
post #1 of 4 Old 01-14-2020, 10:32 PM Thread Starter
Tomcorr
Help me. Understand
What is the difference between the 249 transfer case (Quadra-trac). And the 242 (selec-trac) which was supposed to be more common in 4.0 Laredo’s. Which I have.
Which is better? Which one will last longer?
95 Grand Cherokee Laredo
Tomcorr is offline
post #2 of 4 Old 01-15-2020, 01:05 AM
PolkaPower
PolkaPower's Avatar
The 249 operates in full time all of the time except when in 4low.
It uses a viscous coupler to transfer power as needed. The split is 90 rear 10 front normally so it's almost rear wheel drive.
In 4 low it operates like any other of the two cases. This is for 96-98 only. 93-95 is different.
The 242 full time mode is gear driven and inferior to the viscous coupler in the 249. It also has a thinner chain. The rest of the settings are the same as the 231. The viscous coupler wears out over time and needs replacement and you must maintain your tires because mismatched or improper inflation can wear out a viscous coupler sooner.
It's all personal preference. When my viscous coupler started to wear out I swapped a 242 but I rarely if ever use full time mode. I'd probably just get a 231 next time as they have aftermarket support to beef it up.
Sent from my BND-L24 using Tapatalk
PolkaPower is offline
post #3 of 4 Old 01-15-2020, 06:41 AM
Noble One
Noble One's Avatar
Why a 231? What advantage does it have? And what can be beefed up in it?
Noble One is offline
post #4 of 4 Old 01-15-2020, 07:37 AM
Timo_90xj
Timo_90xj's Avatar
It's worth noting that the '96-'98 is 10-90 front/ rear bias under normal driving conditions, but can split the torque about 50/50 when wheelslip occurs.
'93-'95 is 50/50 initial torque split.
242 full time is a fully open 4wd mode, so if you have one tire on ice and three on dry pavement, you're not gonna move anywhere with the 242 in 4FT.
Smaller in size than a 242/249, it has less moving parts than a 242 so it's more reliable, and it can be beefed up a whole damn lot at fairly affordable price.
As a construction, 249 is just as simple as the 231, it has a wider chain and generally is very strong. 242 is the worst of all three regarding reliability and strength.
***Under construction***
Timo_90xj is offline
