Help me help my brother. - JeepForum.com
post #1 of 6 Old 05-13-2006, 04:08 PM Thread Starter
Jeepinjon
Hi guys, I'm from over on the Yj forum but my brother asked for help with his XJ. I guess I need to know what axles they put on a 96 G.C. Laredo V8. And where/how much for a universal replacement split boot? He also said something about a new axle but I couldn't figure out whether he meant the outter housing or the axle shaft. He's not a car guy and I didn't get to talk to the mechanic...he's in North Carolina, I'm in PA. Any help or suggestions are great appreciated. Thanks.
Jeepinjon is offline
post #2 of 6 Old 05-13-2006, 04:22 PM
anticrombie
anticrombie's Avatar
Xj is the regular cherokee's. ZJ/WJ/WK are the GC's.
If you meant zj, it's the dana 30 with either the dana 35 or the dana 44a.
Charlie
anticrombie is offline
post #3 of 6 Old 05-13-2006, 09:48 PM
Meerkat
The 96 Grand Cherokee is designated ZJ, as opposed to the Cherokee, which is an XJ.
The 96 ZJ has CV joints on the front axles, which is why he is needing to replace the boot. I imagine he has a torn boot. If it has been torn long enough, the CV joint has probably been ruined.
A replacement split boot costs about six bucks in most places. IMHO it isn't worth even that much. With a split boot, you simply wrap the boot around the shaft and then glue the seam closed. This means you don't have to pull the shaft to replace the torn boot. This is a great idea on paper. However, experience shows it is pretty much impossible to keep the CV joint grease off the mating surfaces of the boot. This means the glue will not properly weld the seam closed, which means failure of the new boot in pretty short order.
Pulling the half shaft is not overly difficult, and the CV joint can be properly cleaned, inspected, and repacked before installing a new single piece boot. This is the preferred method. A new single piece boot will run as much as 25 dollars, but often less. Finally, if the CV joint is ruined, he can purchase an entire new half shaft for as little as 55 dollars at Advance Auto or as much as 120 dollars (approximately) at NAPA.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #4 of 6 Old 05-14-2006, 09:06 AM
Swamp Boy
Swamp Boy's Avatar
Yeah.. What Warren said..
Or you can hit a bone yard and pull the shafts out of any TJ or XJ that doesnt have vacum disconnect axles and change the Ujoints and slide them right in..Thus eliminating the CV all together..
Just another soccer moms Grocery getter....
Swamp Boy is offline
post #5 of 6 Old 05-14-2006, 12:06 PM Thread Starter
Jeepinjon
Thanks guys. So he can put a single piece boot on instead of the split? I guess everywhere he went they only had the single piece. As for the mix up on the letter designation, I'm sorry. Never been too good with that.
post #6 of 6 Old 05-14-2006, 01:25 PM
Meerkat
No worries, just making sure we are all talking about the same thing here.
In order to pull the axle shaft, he'll have to remove the wheel, brake caliper/rotor, and bearing hub assembly, then slide the half shaft out. Not too difficult.
HTH
Warren
Meerkat is offline
Brother buying a '96 GC I6 auto with 120k tranny shot shortlid ZJ Grand Cherokee Forum 15 10-17-2009 10:53 AM
Please help my Brother out adgjqetuo ZJ Grand Cherokee Forum 14 09-04-2007 08:21 PM
my brother has been abusing my wj pulsepb ZJ Grand Cherokee Forum 13 12-22-2006 09:05 AM
Varkyls' Long Lost Brother ? Virmagicus ZJ Grand Cherokee Forum 1 06-25-2006 05:51 AM
my brother is driving my jeep tomorrow notfast ZJ Grand Cherokee Forum 6 04-10-2005 09:02 PM
