Help interpreting map sensor readings - JeepForum.com
 1Likes
  • 1 Post By KiloWatts
post #1 of 12 Old 08-21-2019, 01:03 PM Thread Starter
KiloWatts
KiloWatts's Avatar
Hello all,
I've suspected some fuel/air issues for a while and I'm wondering if anyone can help with interpreting my map sensor readings.
It's showing 12.7 inhg at idle, and about 8.5 wot. For kph, it's 43 at idle and about 30 wot. From what I'm reading this is too high overall. My symptoms are long cranks in the AM, and infrequent stalls. Normal operation otherwise, so it's been hard to nail down. Do these numbers look off?
Thanks in advance.
Sent from my Pixel 3 using Tapatalk
1996 4.0 L6 RWD
KiloWatts is offline
post #2 of 12 Old 08-21-2019, 01:34 PM
zjosh93
For stockish stuff idle vacuum should be around 18-20 inhg. At WOT you should be under 3 inhg down to nearly zero depending on how restrictive your air intake system is. So I'd say your idle is too low and the WOT too high. Probably easy enough to double check with a cheap mechanical gauge.
zjosh93 is offline
post #3 of 12 Old 08-21-2019, 01:47 PM Thread Starter
KiloWatts
KiloWatts's Avatar
Hey zjosh93, thanks! I see. Everything is 100% stock, so I'm wondering if it's a problem with the map sensor, or what else could cause such readings.
1996 4.0 L6 RWD
post #4 of 12 Old 08-21-2019, 02:00 PM
zjosh93
Been a while since I had to remember vacuum gauge testing results. Low idle vacuum can be worn engine components, valves, rings, etc. Low WOT can be a dirty air filter or an exhaust restriction.
Could also be a bad sensor I suppose. I know the later 4.0 has the MAP sensor on the throttle body but I'm not sure where it's getting the vacuum from so I can't really say.
Most auto parts places have vacuum gauges for $10-$15. I'd think about buying one. Weird that the OBDII isn't picking anything up. I assume you don't have a check engine light and have pulled any codes?
zjosh93 is offline
post #5 of 12 Old 08-22-2019, 06:39 AM Thread Starter
KiloWatts
KiloWatts's Avatar
Yep, no CEL, and no codes. It's such a "barely-there" problem. I guess I'll have to wait until I'm stranded. Kind of nerve wracking because I'm trying to get it in tip-top shape before a 10-day driving trip around New Hampshire. I'll pick up a vacuum gauge in the meantime.
1996 4.0 L6 RWD
post #6 of 12 Old 08-22-2019, 08:47 AM
jtec
jtec's Avatar
2014 JK Wrangler
I would put a vacuum gauge on - confirm the readings, then old school* vacuum leak check .
* a can of carb cleaner as it idles - intake manifolds get the dbl ck.
jtec is offline
post #7 of 12 Old 08-22-2019, 09:59 PM Thread Starter
KiloWatts
KiloWatts's Avatar
Originally Posted by jtec View Post
dbl ck.
Sorry, what is this?
1996 4.0 L6 RWD
post #8 of 12 Old 08-23-2019, 10:15 AM
jtec
jtec's Avatar
2014 JK Wrangler
dbl ck = double check - sorry I get lazy...
Did you try the vacuum leak check?
jtec is offline
post #9 of 12 Old 08-23-2019, 11:29 AM Thread Starter
KiloWatts
KiloWatts's Avatar
Not yet. It's actually started normally the past 3 days and run with no issues. So uh... I guess it's fixed! 😂. I'll try that vacuum trick though.
1996 4.0 L6 RWD
post #10 of 12 Old 08-23-2019, 05:52 PM
Benthal8
Benthal8's Avatar
You probably know this stuff but this guy is amazing at explaining the interrelationship between sensors and air/ fuel mixtures. Iím still checking his 2 videos about fuel trims that preceded this one.
... just in case something in here spurs some ideas.
Benthal8 is offline
post #11 of 12 Old 08-24-2019, 04:08 PM Thread Starter
KiloWatts
KiloWatts's Avatar
This guy is amazing! I'm watching this one first, as suggested:
Benthal8 likes this.
1996 4.0 L6 RWD
post #12 of 12 Old 08-25-2019, 12:06 PM
Benthal8
Benthal8's Avatar
Yes! Same info but he really knows how to lay it out.
Benthal8 is offline
