Help! Alarm won't shut off! - JeepForum.com
post #1 of 9 Old 07-03-2020, 09:57 AM Thread Starter
JeepRocket
My 97 ZJ arm blasting away! I fidgeted with the door wire but no luck! How do I stop it? I need to get home.
JeepRocket is offline
post #2 of 9 Old 07-03-2020, 12:07 PM Thread Starter
JeepRocket
That should read "alarm is blasting away....." Gotta love modern tech.
post #3 of 9 Old 07-03-2020, 01:49 PM
jeepjeepster
Do you have the keyfob? Press unlock.
If not, try manually unlocking the doors and hatch with the key.
If that doesnt work, youve got something wrong.
1994 ZJ-I6 w/270,000 mi
1998 ZJ 5.9 w/66,000 mi Slate Black
2004 KJ w/108,000 mi
jeepjeepster is offline
post #4 of 9 Old 07-03-2020, 02:06 PM Thread Starter
JeepRocket
Well go with "something wrong." Anybody got ideas? Or a wiring diagram?
post #5 of 9 Old 07-03-2020, 07:30 PM Thread Starter
JeepRocket
Ok so. I disconnected the plug from the latch, shorted the terminals, and the alarm shut off. This worked til my next stop when I had to do it again. Has not happened since.
There is this:
https://m.youtube.com/watch?v=l1qCmRQAJ7I
But don't. Know if it works on my model.
Until next time I'm good.
I will also be keeping the paperclip in my center console. 😁
Does anybody have factory or other wiring diagrams that are just as good? Thanks!
post #6 of 9 Old 07-03-2020, 09:31 PM
papitt
Mine does that rather regular So i TAKE MY KEY & Lock & Unlock the drivers door... Open it & crank it & mine goes off.
papitt is offline
post #7 of 9 Old 07-04-2020, 12:23 AM Thread Starter
JeepRocket
Which doesn't work on mine.
post #8 of 9 Old 07-04-2020, 09:32 PM
jeepjeepster
If the alarm is truly going off, starting the engine will do nothing to stop it.
So using the key fob to unlock the Jeep will not make the alarm stop? What are you wanting a wiring diagram of? When does the alarm go off?
post #9 of 9 Old 07-06-2020, 07:25 PM
amcenthusiast
1985 XJ Cherokee
Cycle ignition key one time in the driver door lock -that should do it.
amcenthusiast is offline
