HELP!! 1996 jeep grand cherokee issue - Page 2 - JeepForum.com
post #16 of 20 Old 01-08-2015, 05:08 PM
RCS1300
2005 WK
I have not had my ZJ for a while. Check the fuel pressure at the fuel rail and see if it meets specifications. Sounds like the engine may not be getting enough fuel at idle. Could be a weak, tired fuel pump, clogged fuel filter or clogged injectors.
Please test before replacing. I believe you can borrow a fuel pressure gauge from an auto supply store.
RCS1300 is offline
post #17 of 20 Old 01-08-2015, 10:13 PM
rep-tile
Cash 4 clunkers survivor
rep-tile's Avatar
Originally Posted by Uniblurb View Post
If you go to ZeeJay's ignition section in his dirty dozen thread you'll see a link to the Denso plug wires for your 4.0 for only $20.
You've replaced all those sensors but what brand did you replace them or are they all aftermarket? While some aftermarket sensors work, many won't, especially when it comes to the crank sensor.
When I had a bad Mopar crank sensor often my 96 4.0 would fail to start 1st thing in the morning when cold. Not as cold as there but complete the below crank sensor test in a no-start condition to see if you're even getting a crank sensor signal? Let us know what you find and good luck.
http://troubleshootmyvehicle.com/jee...crank-sensor-1
X3
When it comes to sensors, always go OEM. Most aftermarkets are cheap junk... and some are good in term of quality, but aren't calibrated right for the Jeep (like the Bosh O2 sensors being notorious for causing issues on the 4L).
This can't be said enough. Whenever possible, test it instead of throwing parts at it.
rep-tile is offline
post #18 of 20 Old 01-09-2015, 04:24 AM
ZeeJay1997
dont go changing all the sensors again because they're not mopar. they may be fine. if your problem has not changed since you started changing things, it's probably okay
ZeeJay1997 is offline
post #19 of 20 Old 01-09-2015, 10:57 AM
Uniblurb
Uniblurb's Avatar
While I'll always push for Mopar sensors I'd tend to agree with Zee since you have so much money invested in them. When I came on here a few years ago he taught me testing since I was throwing so many parts at my 96 4.0 for a stalling problem along with an erratic no-start condition. Turned out a bad engine/PCM ground on the coil stud took out a couple PCM's along with a couple Mopar crank sensors.
Having said that I did buy a couple crank sensors from Advance which were just as bad/finicky as the bad Mopar one I was trying to replace. But I know Zee is running a jewel of a crank sensor from NAPA which hasn't given him any problems. Does this mean all crank sensors from Advance are bad while all NAPA crank sensor are good, probably not. It's a crap shoot since so many parts are outsourced overseas these days and even Mopar does it.
RCS1300 brings up a real good point about checking for fuel/pressure which didn't see on your list. Many auto parts stores have loaner fuel pressure testers and spec is 49psi +/- 5psi. Also the fuel system shouldn't bleed off below 24psi after 10-30 min if everything is working correctly. Taping the fuel gauge face to the windshield is a trick I learned from Zee to check pressure while driving.
It should be noted there was a TSB issued on the 96 4.0/5.2 fuel pump in particular for overheating problems. It sure isn't going overheat a -30 but as with any other motor overheating does shorten the motor life. I had to change my 96 OE fuel pump out at about 195-200K miles since it was failing.
Great below deal at $120 for a new Bosch fuel pump module but again, do some extensive testing first. Bosch is OE and Mopar just repackages the same pump module while selling them for a whole lot more.
http://www.ebay.com/itm/NEW-BOSCH-67...2512b8&vxp=mtr
Lastly, the fuel filter is easy to change out on the 96 and you may want to try this if it hasn't been done in a while. And it doesn't hurt to add a fuel additive like "Heet" to your fuel system to try and clear any water out which happens at those low temps. Good luck!
2004 4.7L WJ Limited, 96 4.0 ZJ
Uniblurb is offline
post #20 of 20 Old 01-09-2015, 01:40 PM Thread Starter
Chasekt98
I have not yet checked fuel pressure, however fuel filter has been replaced, cps sensor is getting good signal. Im hoping on being able to replace plugs with copper resistor plugs today. Ill let you know how it goes.
Chasekt98 is offline
1996 , grand cherokee , jeep , stalling , zj
