Heater blower motor going out, have to hit it for it to work. - JeepForum.com
 2Likes
  • 1 Post By Skippynutz123
  • 1 Post By V8GCZJ
post #1 of 11 Old 02-02-2019, 03:08 PM Thread Starter
Skippynutz123
I have a 97 JGC, and the blower motor is new, I checked the resistor and replaced it, the only thing I can think of would be the wiring from the resistor, back to the heater switch. The blower motor works a short while after I hit it with a rubber hammer, and then it sometimes will stop completely. So mad, because I live in Alaska, and its frustrating to have to hammer the motor, to get the windows defrosted. If anyone has a wiring diagram, that would be awesome! Thank you.
Skippynutz123 is offline
post #2 of 11 Old 02-02-2019, 07:10 PM
ZeeJay1997
Find the wiring going to the motor. Follow it and unplug ever connector you find. Most likely you'll find a burned wire.
ZeeJay1997 is offline
post #3 of 11 Old 02-03-2019, 02:00 AM Thread Starter
Skippynutz123
Or could it possibly be the Climate control Module? The heater fails to start, when I turn the key, but with a slight tap on the blower motor, turns it on temporarily, and after a few minutes, shuts off.
post #4 of 11 Old 02-03-2019, 02:03 AM Thread Starter
Skippynutz123
Checked all of the connections, and all are good, I'm thinking it's the climate control module.
post #5 of 11 Old 02-03-2019, 08:22 AM
ZeeJay1997
Did you take the connectors apart and look at them? The blower motor wiring contacts will get corroded and burn up from high current.
There's a blower motor relay that could be a problem.
Here are the schematics. Good luck.
post #6 of 11 Old 02-03-2019, 11:30 AM Thread Starter
Skippynutz123
Yes, I looked at the connectors, I was hoping it was that, because the digital climate control module is $170, and not cheap. I've checked everything else. Next I will try with a new module. Thank you.
post #7 of 11 Old 02-03-2019, 01:07 PM
GOLDWING
GOLDWING's Avatar
It is possible that the brushes in the blower motor are toast. Rapping on the motor will cause them to contact the commutator just a bit better. I suggest jumping power and ground to the motor before looking further.
Rock Auto has the blower motors for $30-$40.
GW
"The Dude Abides"
GOLDWING is online now
post #8 of 11 Old 02-04-2019, 05:35 AM
jeepjeepster
GW
Its possible the new motor is bad but he said that he replaced it.
Not sure if the control module would be bad if hitting the motor with a rubber mallet makes it come on.
1994 ZJ-I6 w/270,000 mi
1998 ZJ 5.9 w/66,000 mi Slate Black
2004 KJ w/108,000 mi
jeepjeepster is online now
post #9 of 11 Old 02-12-2019, 12:53 AM Thread Starter
Skippynutz123
So I originally replaced the blower motor a couple of years ago, and I think I ended up getting a bad replacement motor, because I just replaced it again, and it's working like brand new!
GOLDWING likes this.
post #10 of 11 Old 02-12-2019, 12:18 PM
GOLDWING
GOLDWING's Avatar
When you hear hoof beats, don't think zebras.
GW
"The Dude Abides"
post #11 of 11 Old 02-12-2019, 06:06 PM
V8GCZJ
LOL!
V8GCZJ is offline
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3864 10-19-2019 10:58 PM
97/98 Fan Control Switch noise_maker TJ Wrangler Technical Forum 3 01-29-2019 02:06 PM
Heater Core replacement: What I learned FairlanePhil XJ Cherokee Technical Forum 10 12-04-2018 08:11 PM
99 XJ Blower Motor won't work. Mywifes99XJ XJ Cherokee Technical Forum 5 11-17-2018 03:28 AM
Blower fan wont work. (Even new one wont) JonMopar ZJ Grand Cherokee Forum 3 12-02-2017 04:34 PM
