grounds - JeepForum.com
 1Likes
  • 1 Post By 98CherokeeLTD
post #1 of 10 Old 03-24-2019, 10:04 AM Thread Starter
98CherokeeLTD
grounds
Im trying to get to the bottom of why my gauges, power windows, and overhead console have stopped working, i know it could be a bunch of different things. i checked the fuses and replaced the cluster plug in the dash harness. i figure next i should locate and check the grounds. my question being, does anyone have a list of the grounds and their locations? i have the FSM which tells me that there are grounds, but not where they are specifically. I found all kinds if lists for other models, but not the ZJ.
any help is greatly appreciated
98CherokeeLTD is offline
post #2 of 10 Old 03-25-2019, 12:15 PM
MaintMech
Old and in the way
MaintMech's Avatar
https://www.jeepforum.com/forum/f13/...u-post-880249/
Here's a place to start.
Search is a good thing.
'96 Grand Laredo, 4.0, Stock, Daily Driver
I fought Oracle and Oracle won!
Originally Posted by coralman
If the faith isn't there,the doubt is.
MaintMech is offline
post #3 of 10 Old 03-25-2019, 09:44 PM
RedRiverT
https://www.manualslib.com/download/...-Cherokee.html
That's a manual for a ZG, the European version, but the wiring shouldn't be greatly different. Page 8W-15-1 is the ground locations. I've seen one, or at least posted pages of one, that has a description of where the ground screw actually is. I don't know if this linked one has it or not.
RedRiverT is offline
post #4 of 10 Old 03-26-2019, 02:48 PM Thread Starter
98CherokeeLTD
I've used search, multiple times, with little to no success. Hence the reason I posted here. I'm no newb to JF.
I'm not saying the info isn't available, but I've been unable to locate it.
Sent from my Galaxy S7 using Tapatalk
post #5 of 10 Old 03-26-2019, 02:52 PM Thread Starter
98CherokeeLTD
That's the same manual I have already. It lists the ground #'s G300, G102, ect, but no description of the location of where the bolt is.
Thanks tho, good looking out.
After doing a lot more scouring through pics, schematics, threads, and such, I have gotten a few locations...haven't had time to get outside to actually check if they are correct.
When I get them figured out, I will post what they are.
post #6 of 10 Old 03-26-2019, 04:42 PM
GOLDWING
GOLDWING's Avatar
IIRC, the ground in question is under the drivers seat between the two rear seat mount bolts.
GW
"The Dude Abides"
GOLDWING is offline
post #7 of 10 Old 03-30-2019, 12:44 PM Thread Starter
98CherokeeLTD
GW
Ok.
I still havent been able to made any progress with this, between my work schedule and rain. SMH
I don't mind not having a tach or speedo, it's the no temp and no fuel that really bother me.
post #8 of 10 Old 04-27-2019, 07:56 AM Thread Starter
98CherokeeLTD
So, as promised, I said I'd post all the grounds locations if I was able to get them all. After countless hours scouring the intewebs and FSM, I finally found a list in the FSM. Ground #, physical location and illustration. Here's a pic of the list. Didn't take pics of the illustrations, however.
I've checked all the grounds except for the ones under the driver and passenger seats as I need to pull the seats, console, surrounding trim and carpet.
I did a lot of volt and continuity testing on wires and plugs pertaining to the cluster and BCM but came up with nothing (not saying there is no issue, I could have easily missed something) also went to the pick n pull and got a BCM, which didn't fix the issue. (I know, that BCM could be friends)
Need to check those remaining grounds and for good measure I'm going to get a cluster, as to rule that out (or *fingers crossed* solve the problem.
kachink likes this.
post #9 of 10 Old 04-29-2019, 05:46 AM Thread Starter
98CherokeeLTD
After installing another cluster, no luck.
Have to get those last 2 ground locations exposed and checked.
Unfortunately, tomorrow and Wednesday are my only days off between now and the 17th, and the weather doesn't look promising.
I miss having a garage to work in.
post #10 of 10 Old 05-16-2019, 12:49 AM
BRBauer2
Any luck getting to those grounds?
Any chance you too pictures?
I'm chasing a ground issue and having an idea what is needed for these would be great.
Thanks for the info you've found already!
Sent from my ONEPLUS A6013 using Tapatalk
BRBauer2 is online now
12 Things You Can Do When Your ZJ Stalls ZeeJay1997 ZJ Grand Cherokee Forum 448 05-28-2019 07:14 PM
Questions on grinding noise and grounds Kitkatsha WJ Grand Cherokee Forum 4 12-09-2018 10:15 PM
PCM Grounds and Input voltages aholt WJ Grand Cherokee Forum 32 07-26-2018 08:28 PM
Grounds Mopar4U ZJ Grand Cherokee Forum 2 01-14-2018 06:30 PM
2.5 TJ alternator and grounds question pic request rielcrazy Engines & Drivetrain 1 12-19-2017 09:16 PM
