Grease boot question - JeepForum.com
post #1 of 13 Old 07-05-2020, 01:25 PM Thread Starter
KiloWatts
KiloWatts's Avatar
I just finished installing a Crown HD drag link and tie rod assembly and noticed 3 out of 4 grease boots won't take more than a squirt or two of grease. Usually I'm able to force out the old grease but my gun won't even pump with these. The 4th boot seems to be normal soft rubber and functions/expands like normal, but the other 3 seem to be made of harder, inflexible material, and have some raised ridges on top.. What's the deal with these?
1996 4.0 L6 RWD
KiloWatts is offline
post #2 of 13 Old 07-05-2020, 03:33 PM
hilljacknm
Had the same issue with Crown parts. Hope I can get some grease in there after driving around a while. Also had under sized zerks that didn't seal well on the grease gun .
1996 ZJ 5.2
Doug Thorley Headers, Kolak exhaust
BFG KM3 30x9.50"
hilljacknm is offline
post #3 of 13 Old 07-05-2020, 03:52 PM Thread Starter
KiloWatts
KiloWatts's Avatar
Very interesting... I did try a new zerk on one of them but it behaved the same way. I wonder why they have the weird boots and if that has anything to do with it.
1996 4.0 L6 RWD
post #4 of 13 Old 07-05-2020, 04:31 PM
hilljacknm
I don't think the boots have anything to do with it. One of my boots is already ripped/missing. Maybe I drove over some brush and ripped it off?
1996 ZJ 5.2
BFG KM3 30x9.50"
post #5 of 13 Old 07-05-2020, 05:25 PM Thread Starter
KiloWatts
KiloWatts's Avatar
Yeah, I've tried different zerks now and it makes no difference. I think the ball itself is blocking passageway for any grease to enter the boot. I think maybe I'll try a different brand next time.
1996 4.0 L6 RWD
post #6 of 13 Old 07-12-2020, 08:07 PM Thread Starter
KiloWatts
KiloWatts's Avatar
Bumping this in case anyone else has experienced. I found some other threads that say sometimes they forget to drill through to the ball at the factory and suggested sticking a drill bit up inside.. Which seems crazy to me. I'm thinking about taking them back off and inspecting.
1996 4.0 L6 RWD
post #7 of 13 Old 07-13-2020, 01:28 AM
Zilliver
Live with them some time and then try to add grease again.
I had one tie rod end with similar problem, no grease will go in after installing. Tried like 3 different grease guns from my friends. About 6 months later when I did an oil change I tried again to grease it, and it worked. Tie rod was ok for many years also after that. I sold the car after that so I dont know how long it finally lasted.
98 Grand Cherokee 5.9 - daily
95 Grand Cherokee 5.2 - offroad
Zilliver is offline
post #8 of 13 Old 07-13-2020, 08:22 AM Thread Starter
KiloWatts
KiloWatts's Avatar
You say this under the assumption that I have enough patience to quiet my brain's incessant worries about a dry ball joint. But I'll try
I do actually have these poly grease boots that I forgot to put on. Maybe if they're still giving me trouble in a few months I'll do a swap and take a closer look then.
1996 4.0 L6 RWD
post #9 of 13 Old 07-19-2020, 06:24 PM
hilljacknm
Tried to grease the problem joint today. Still can't get grease in there. This is the driver side tie rod end.
1996 ZJ 5.2
BFG KM3 30x9.50"
post #10 of 13 Old 07-19-2020, 09:27 PM
ravenworks
ravenworks's Avatar
Very simple,pull.the zerk,stick a pick in the hole and check to see if there is any dried grease in there.
As for guys finding undersized fittings,they are metric zerks.
As for properly greasing a joint,I'll let you guys figure it out
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline
post #11 of 13 Old 07-21-2020, 07:12 AM
Calentarse
I know one of my boot is leaking because it ruptured. They're original to my Jeep, and so are the tie rods. I have 174,000 miles. Does anyone know how much it'd be to have a shop replace the tie rods? I have some sounds coming from that area so I'm thinking it needs to be done.
Iím an educator, tinkering using forums and YouTube for my own repairs.
Calentarse is offline
post #12 of 13 Old 07-21-2020, 12:07 PM Thread Starter
KiloWatts
KiloWatts's Avatar
I popped off two of my joints last weekend and inspected. They're pre-greased so at least they're not dry. Still can't get any new grease in them. I replaced the boots with some ES poly boots I had and reassembled. I guess I'll try again later.
1996 4.0 L6 RWD
post #13 of 13 Old 07-22-2020, 10:19 AM
MaintMech
Old and in the way
MaintMech's Avatar
Just a thought. Next time you have them off take them to your local garage. Have them try and grease with their (hopefully) high pressure greasing machine. Can't hurt.
'96 Grand Laredo, 4.0, Stock, Daily Driver
I fought Oracle and Oracle won!
Originally Posted by coralman
If the faith isn't there,the doubt is.
MaintMech is offline
