getting the doors off - JeepForum.com
post #1 of 49 Old 10-04-2005, 09:27 PM Thread Starter
zj333
Guest
ok so ive been wanting to do it all summer and now its pretty much my last chance since the weather is gonna take a turn for the worse real quick, anyway to the point how do i get the dooors off my ZJ!?!?!?! and if i do get them off how easy is it to put them back on, wil they go on easy or is this a difficult task i shouldnt fool with
zj333 is offline
post #2 of 49 Old 10-04-2005, 09:35 PM
grygg
Guest
I just replaced 1 of my front doors, 4 bolts and disconnecting 2 wire harnesses (they connect a few inches up under the dash). Pretty easy.
grygg is offline
post #3 of 49 Old 10-04-2005, 09:40 PM
grandman97
Guest
yea thats its the 4 bolts clip the wiring harness and boom... one problem i ran into was the dome lights wouldnt shut off so i just unscrewed the little rubber sensor thingy on the door jamb and that solved that problem... i'd get a buddy to help u cuz once u get that last bolt off the doors gunna wanna go south fast!... one more thing unclip the wiring harness before unbolting so u dont have your friend there holding the door still while u try to unclip the harness.... doorlessness is great but on the roads u gotta have a mirror
grandman97 is offline
post #4 of 49 Old 10-04-2005, 09:45 PM Thread Starter
zj333
Guest
what do you mean by clip the wire harness like cut it i dont want this to be permanent i just want it to be like maybe for a day or two, is it jus tnot worth the trouble
zj333 is offline
post #5 of 49 Old 10-04-2005, 10:03 PM
OffroadZJ
OffroadZJ's Avatar
inside the cluster of wires is a torque bit screw that holds the connector together. Take that off, and you are good to go.
Kenny
1994 5.9L ZJ. RK 7" long arm, 35" Super Swamper Trxus M/T mounted on Pro Comp extreme alloys. Ford 8.8 w/ 4.10 and powertrax locker, hp30 w/ 4.10 (open for now), Warn Tabor 9000. Soon to come: Hanson Enterprise front winch bumper, hand made rear bumper with carrier, hand made skid plates. 242 case is sitting in my garage waiting for a warm day to transplant.
OffroadZJ is offline
post #6 of 49 Old 10-05-2005, 05:07 AM
93redzj
Guest
93redzj is offline
post #7 of 49 Old 10-05-2005, 05:13 AM
CanadianZed-J
Just race a Jimmy at the next red light. He'll blow the doors right off the thing. :d
So I installed the flux capacitor but the Jeep just won't do 88 mph.
-'99 WJ Limited, 4.7, Patriot Blue, 2" BB, 31" Mall-Terrains, Pavement Princess
-'97 TJ, Stone White, 4" Superlift, 33" SSRs, lunchboxed rear, 12K Titan winch, and 2.5 litres of exhillirating performance.
CanadianZed-J is offline
post #8 of 49 Old 10-05-2005, 09:50 AM
mawardjr
Guest
On 96+ ZJ's there isn't a torque bit screw in the harness.
There is a safety clip (should be red), slide it to the other side then there is a tab at the top of the plug that you'll have to press in to pull it apart. It is a tight fit but it will come loose with some patience.
To kill the dome light - just pull the fuse or you can install a switch for it.
My doorless ZJ ...
mawardjr is offline
post #9 of 49 Old 10-05-2005, 11:16 AM
grygg
Guest
My doorless ZJ ...
hmm. I don't remember this "torque bit screw" on my 94. It was just a pain to get that clip off. In fact, I watched the guy wrench my replacement door off another 94 at the boneyard and he didn't take any screw out either, just a PITA clip.
grygg is offline
post #10 of 49 Old 10-05-2005, 01:47 PM
mawardjr
Guest
I have no idea what a 93-95 harness looks like. My response was result of OffroadZJ's post and his comment about the screw.
mawardjr is offline
post #11 of 49 Old 10-05-2005, 03:51 PM
mr_user
My doorless ZJ ...
Or for a temporary fix, just unscrew the small push tab on the door jamb to unground the switch. With this discoe'd you'll never get dome lights with the door open.
Matt
Old: '96 ZJ 4.0, 32" MT/R's, 4.5" Lift, Mickey Thompsons, JKS Disco's
New: '02 WJ Limited 4.7L, Stock for now
mr_user is offline
post #12 of 49 Old 10-05-2005, 04:02 PM
Woody
Retired back to Bowties
Woody's Avatar
1985
Originally Posted by Unlimited77
Heres a no brainer! - BuY A WRANGLER!
"There's only One Jeep!" (And it aint a cherokee)
Okay, who let the spoiled brat in here. Some of us like to wheel with class. Why have a Wrangler, they're all over on the trails. When I go wheelin' I draw attention because you don't see many Grands on the Trails. Wranglers ride like crap, get crap for mpg, are noisy, and are usually driven by morons. I say that because on average one Wrangler a weekend is rolled down where I go by Chiva falls. The roll because they don't think prior to attempting the obstacles.
Enough ranting. I cannot go doorless because I'm hauling three kids with me when I go out. I wouldn't want to have one fall out accidentally.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #13 of 49 Old 10-05-2005, 04:57 PM
10achik
I ate what?
10achik's Avatar
Why are you lurking in the Grand forum anyway? Nobody likes a hater, were all a freindly group over here, no need for all this. Plenty of other forums that encourage your behavior.
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 35's
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Ebiach Pro Kit w/ swaybars, EVO Ventus V12s (13.76 @ 103.85)
2006 Pontiac G6 GTP
2012 Nissan Juke - (hers)
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
10achik is offline
post #14 of 49 Old 10-05-2005, 05:35 PM
10achik
I ate what?
10achik's Avatar
You did cast the first stone...how was your original comment helpful. the guy want's to know about taking his doors off and you tell him to buy another vehicle and then slam a cherokee saying it's not a Jeep.
And how am I bustin your nuts? I just pointed out that there was no need for your original comment. You expect for everything to be all happy happy when you jump into a forum, and slam everyone's vehicle in that forum with your comment.
If your done, I'm sure grygg would like to get some helpfull info since we are so far off topic.
Before you respond back with somehting else hateful, is it worth getting BANNED over. Go read the Rules of Posting and you will see that you are walking a thin line already.
Ken
2006 Pontiac G6 GTP
10achik is offline
post #15 of 49 Old 10-05-2005, 05:58 PM
Animal Mother
Guest
i smell another mmmeat.. Does anyone know how and where to mount mirrors without the doors? Its so hot here over the summer id love to be doorless.
Animal Mother is offline
help me take off my doors ccppcc90 ZJ Grand Cherokee Forum 16 09-26-2008 10:34 AM
Doors of the WJ???? SouthernboyWJ ZJ Grand Cherokee Forum 10 04-23-2008 06:16 PM
doors off kennyb ZJ Grand Cherokee Forum 11 02-16-2007 10:43 AM
doors off randyszj94 ZJ Grand Cherokee Forum 7 04-02-2006 11:35 AM
Switched '93 Front Doors with '97 Front Doors...now nothing works bigbrowndog ZJ Grand Cherokee Forum 0 03-14-2004 03:03 PM
