Fuel light on and gas on E when there is gas in the tank? - JeepForum.com
post #1 of 9 Old 01-22-2011, 11:22 AM Thread Starter
adaptapter
Hello everyone. I just bought a 98 ZJ Laredo 5.2L and twice when I am in park the gas meter went on E and the fuel light came on when I know my tank was over half full. It went away right when I started driving so I am wondering what the cause could be? I do have a CEL on for emissions so maybe it could be related? Thank you.
Don
adaptapter is offline
post #2 of 9 Old 01-22-2011, 11:55 AM
Coolcatracing
Sounds like either your sender in th tank is bad or you have a short on the signal wire. I believe a total ground on that circuit reads empty, if it's the other way around then you may have a loose connection or broken wire.
08 Unlimited Rubicon 6 speed, 315/70-16 Kelly TSR, 1.5" Spidertrax spacers factory Moab's, Rubicon Express Flex arm 3.5" lift, Smittybilt XRC front bumper with D-rings, Body Armor Extreme rock slider steps, AEV snorkel, trimmed fender flares, Hella 8" HID driving lights
Coolcatracing is offline
post #3 of 9 Old 01-22-2011, 03:34 PM
Trizunky
I have this happen to me a couple of times also. LOL the first time it happened to me I thought someone had robbed my tank.
Just turn off engine and restart and it goes away. Not a cure but I really dont have the cash to mess with it.
Trizunky is offline
post #4 of 9 Old 01-22-2011, 04:58 PM
93GurblackZJ
Fuel level sensor is junk, has seen this quite a few times. Only fix I believe is to throw a new pump in it, which involves a little bit of work and an expensive part. I would keep an eye on it and if vehicle performance or gas mileage drop or you notice something just isn't right its time for the pump to go.
93 Wooped Multicolored ZJ, Sold
96 Super Clean ZJ, favorite truck ever. Lost fight with a pole, totaled. Sold
00 Black XJ, Headgasket failure victim, Rage roof rack, Bumper Hella 500's and Rear Cb antenna. 3 Inch rear lift and 2 Inch front lift. 31 Inch Firestone Destination A/T's
93GurblackZJ is offline
post #5 of 9 Old 01-22-2011, 09:13 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Every chrysler product from the 90's-2000's does this. A new sending unit doesn't totally fix it.
ratmonkey is offline
post #6 of 9 Old 01-22-2011, 11:02 PM
newfieZJ
newfieZJ's Avatar
I must not be looking when it happens to me
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #7 of 9 Old 01-22-2011, 11:14 PM
indredsnake99
indredsnake99's Avatar
what parts are involved in fixing this since it happens on my jeep and drives me carzy and i want this annoying problem fixed
Wayne
1997 formerly GREEN now rustoleum bed lined zj 4.0 np242 bought 9/25/2008
gone
1998 5.9l platnium zj np249 k&n sct bought 4/6/2010
2007 sahara 2 door wrangler stock bought 02/08/2011
Originally Posted by ZJones View Post
You'll learn a lot. I didn't know anything when I first joined this site either. (not sure if that's changed at all :laugh:)
indredsnake99 is offline
post #8 of 9 Old 01-22-2011, 11:18 PM
94chb
94chb's Avatar
my previous 97 zj if the gas level was below half a tank the gauge would read E, my new 98 would just goto E for no reason at anytime and gas light would come on, not long ago my pump died on me, 186$ and i changed it in a church parking lot, its been workin perfect since. funny thing is i sold a rear end to a guy for $200 and delivered it. as soon as i got there and delivered it and got paid my pump went out, so we both had to work on our zj's in a parking lot side by side. his rear end blew out, literally, it had 2 holes in the housing and had caught fire when he was driving it to work.
94chb is offline
post #9 of 9 Old 01-23-2011, 12:14 AM
aircruiser
aircruiser's Avatar
it happened on my xj..if you are lucky enough, it just popped off the mount on the fuel pump. im not sure if you can replace it as just the part or if you have to get a whole new pump but its a little chip on the side of the pump in the tank
aircruiser is offline
Fuel Gauge Needle is dead... Low Fuel Light always on... any ideas? 95_JGC ZJ Grand Cherokee Forum 20 03-30-2015 09:30 PM
Fuel tank is only filling to 3/4 of a tank bammers85 WK Grand Cherokee & XK Commander Forum 11 12-11-2009 08:23 AM
WK 05 fuel spill via fuel tank juanowk05 WK Grand Cherokee & XK Commander Forum 0 11-26-2008 07:36 AM
Fuel Pump/Fuel Tank Problem ma-usa1 ZJ Grand Cherokee Forum 18 04-09-2008 07:28 PM
Fuel Pump/Fuel Tank Problem ma-usa1 ZJ Grand Cherokee Forum 0 02-05-2003 06:02 PM
