Fuel Injectors question - JeepForum.com
post #1 of 8 Old 05-15-2021, 05:04 PM Thread Starter
blueribb
1998 Jeep Grand Cherokee Laredo 4.0L
148,000 miles
Mint Condition
For the last few years the idle has been less and less smooth. The dash buzzes and the tach sometimes fluctuates between 400 and 750 RPM. It never stalls but sometimes it feels like it's going to.
I am not a mechanic and rely on a local service station to keep my Jeep in order. They have cleaned various parts to help solve this issue but nothing has helped. I had the plugs, wires, distributor cap and rotor replaced with new OEM parts. It runs a little better but still shakes a little during idle.
I am having the Idle Air Speed Motor replaced next week with an original Chrysler part ($100 from Amazon). If that doesn't work, I may want to change the fuel injectors. They have never been replaced. After searching for the original OEM Injectors, I found they are super expensive (around $100 each) and somewhat hard to find). I then found out that the original Siemens brand injectors are known for leaks and a lot of people are recommending using remanufactured Bosch Injectors (4 spray holes) as an upgrade. There's a company called CS Performance that sells a set of 6 OEM Bosch III for $127 on Ebay that will fit my Jeep.
I want to find out what you guys think about replacing the fuel injectors.
blueribb is offline
post #2 of 8 Old 05-15-2021, 05:52 PM
yjsaabman
1930 CJ2
I don't have any input on this topic, but I am definitely interested in the topic. Do you have a link to those injectors? I will be reading up on this.
Sent from my SM-G970U using Tapatalk
yjsaabman is offline
post #3 of 8 Old 05-15-2021, 06:48 PM Thread Starter
blueribb
https://www.ebay.com/itm/190827041197
blueribb is offline
post #4 of 8 Old 05-15-2021, 07:32 PM
riiz
riiz's Avatar
Have them rebuilt. $50 for 6 injectors. I personally dont think the 4-hole injectors improve anything. They are a cheap alternative, if you have to replace injectors.
https://www.ksuspensionfab.com/store...Service.html#/
riiz is offline
post #5 of 8 Old 05-16-2021, 01:44 PM
mikem350
1994 ZJ
My '94 has same rough idle problems time to time. Whats works for me is to use Seafoam Motor treatment (add to gas) every couple fill ups.
My experience, it does work, but takes time. Root cause is clogged injectors.
Proud owner of two DD 4.0 ZJs
Flame Red 94 mint!
Silver 98 just hit 360k miles....runs great!
mikem350 is offline
post #6 of 8 Old 05-16-2021, 02:40 PM Thread Starter
blueribb
I'm not much for additives but I'll give this a try.
Thanks
blueribb is offline
post #7 of 8 Old 05-16-2021, 08:29 PM
PolkaPower
PolkaPower's Avatar
It'll idle and accelerate smoother with new injectors but nothing else.
Sent from my iPhone using Tapatalk
PolkaPower is offline
post #8 of 8 Old 05-18-2021, 09:26 AM
Black93ZJ
My 93 has the original Siemens injectors, but I have an injector pulser and scan tool that does actuations to aid in cleaning. I use to pull mine once a year, back flush the injectors, and then squirt brake clean while pulsing them to clean out any gunk left. Mine would stumble from time to time at idle, but my coil was going bad and once replaced it quit doing that. Also run Shell gas through it for a few tanks as they are suppose to be top tier gas, and run at least one to two tanks of the 93 with V power to see if it clears up before buying parts you may not need. I soley run 92 to 93 octane in mine and very rarely had any engine gunk problems.
Black93ZJ is offline
