Fuel consumption is too high - Page 2 - JeepForum.com
post #16 of 18 Old 05-05-2017, 11:16 AM Thread Starter
leone1907
Originally Posted by StPaul59 View Post
What was your method for resetting the ecu?
car mechanic made. computer connected odb port
leone1907 is offline
post #17 of 18 Old 05-05-2017, 11:59 AM
xteban
How do you drive? If you are always in high traffic, stop and go, you won't get much better milage than you are having now.
1996 ZJ 5.2 - Dark Rosewood Pearl Coat (purple with glitter)
xteban is offline
post #18 of 18 Old 05-05-2017, 12:12 PM
StPaul59
That won't erase the adaptive memory. The only way I have found to do it properly is disconnecting BOTH battery terminals and connecting them together for a minute. I use a piece of metal, an open ended wrench because mine don't stretch that far. Reconnect them. Turn the ignition on without starting it, Turn headlights on and then turn them off. Turn ignition off and wait for the click. Then all good to go. I usually cover my battery with a towel to keep from accidentally touching them while grounding my terminals together.
https://www.jeepforum.com/forum/f67/r...emory-1265118/
StPaul59 is offline
1995 , fuel , performance
