Front sway bar links - JeepForum.com
 1Likes
post #1 of 48 Old 03-01-2019, 04:04 PM Thread Starter
igorhandsome
igorhandsome's Avatar
I bought the Mevotech MK3174 front sway bar links. What is the trick to installing them? They are different than stock style ones and we're having no luck getting them in.
igorhandsome is offline
post #2 of 48 Old 03-01-2019, 04:14 PM
GOLDWING
GOLDWING's Avatar
AC delco has these which match the ones on my '98. R.A.ACDELCO 45G0220 {#89030095} Professional Info
Front $23
GW
"The Dude Abides"
GOLDWING is offline
post #3 of 48 Old 03-01-2019, 04:18 PM Thread Starter
igorhandsome
I realize I can buy those style. But I have already got the other ones and was looking for the trick to getting them installed
3hounds likes this.
post #4 of 48 Old 03-01-2019, 04:25 PM
GOLDWING
GOLDWING's Avatar
I wish I could help, Igor. I've never messed with that type. They look like they would be stronger than the OEM ball joint style.
The AC Delco units I put into the rear sway bar of my '98 5.2 look similar so maybe you can look at the back links and see how they are set up.
GW
"The Dude Abides"
GOLDWING is offline
post #5 of 48 Old 03-01-2019, 04:44 PM Thread Starter
igorhandsome
I did the rear ones and they went in without any issue. Old ones were shot and snapped off during removal. Much better design than the original ones.
post #6 of 48 Old 03-01-2019, 05:12 PM
Some_Anchovies
Some_Anchovies's Avatar
They look exactly like the style on my 95'. What issues are you running into? I've replaced mine a few times throughout the years, it's easiest to do both at the same time.
It may be that the sway bar design is different cause I think the links are taller, but I always just unbolted the sway bar from both sides, pushed the swaybar up, pulled both links out, put the new links on, bolted the bottoms on just enough so they would stay upright, and then lowered the sway bar back down and aligned both sides before bolting the top bushing down and tightening the bottom nuts.
95' ZJ 4.0L, 5-Speed Manual, NP231, 5.9 seats, Upcountry Lift, 265k
Some_Anchovies is offline
post #7 of 48 Old 03-01-2019, 05:36 PM
1996maroonzjf
You have to drill out the sway bar holes to accept the larger diameter links.
I upgraded my original stock sway bar to 93-95 style on my first ZJ before I upgraded to JKS Quicker disconnects and eventually an addco.
Have fun drilling the spring steel on the sway bar. It took ages with a cordless drill IMS.
-Tim
(2) '96 4.0s
#1-'10-'18
#2- HP30/Ford 8.8 - 4.56, OME HDs, 5100's, IRO Adj Arms/Track Bars
1996maroonzjf is offline
post #8 of 48 Old 03-01-2019, 05:43 PM Thread Starter
igorhandsome
Ah gotcha that makes sense now. Do you recall what size?
post #9 of 48 Old 03-01-2019, 07:12 PM
paulvon
Depending upon the year the sway bar will have a different outer diameter and the links will be a different style.
The earlier bar had a larger diameter. I upgrade my 97 with one from a 93.
Sent using Tapatalk
1997 ZJ 4.0 L - Upgraded to heavy 93 sway bar
2004 WJ 4.7 L - 2 1/2" lift
2011 KK 3.7 L
paulvon is offline
post #10 of 48 Old 03-01-2019, 07:22 PM
1996maroonzjf
I do not. Just bring the new links to the store or measure them.
-Tim
(2) '96 4.0s
#1-'10-'18
post #11 of 48 Old 03-04-2019, 11:20 AM Thread Starter
igorhandsome
So I have the links installed now. Unfortunately on any up and down suspension travel I now have a noise that must be due to these new links. Everything feels fine driving but any bumps cause the noise...any ideas?
post #12 of 48 Old 03-04-2019, 11:56 AM
zjosh93
What size hole did you drill? The hole is surprisingly large, roughly the same diameter as the lip on the bushing.
zjosh93 is offline
post #13 of 48 Old 03-04-2019, 12:13 PM
StPaul59
I run the solid design (95s) on my 98 with the addco bar. I have about 8 washers on the pass side to keep the addco bar from hitting my track bar mount on the drivers side.
StPaul59 is offline
post #14 of 48 Old 03-04-2019, 01:27 PM
firebane
Swaybar end links for the front depend on the year. The 1st gen and 2nd gen are different styles and you need to ensure you have the right ones.
firebane is offline
post #15 of 48 Old 03-04-2019, 02:23 PM
HighLonesome
HighLonesome's Avatar
What sort of noise?
HighLonesome is offline
Install Factory Front Sway Bar, BUT!!! aldoylemini Jeep CJ Forum 8 09-23-2018 01:07 PM
sway bar links BackwoodCrawler WJ Grand Cherokee Forum 4 05-02-2018 03:29 AM
Sway bar bushings and end links. xcaliber81 WJ Grand Cherokee Forum 2 04-16-2018 07:41 AM
Front sway bar end link busted json1123 JK Wrangler Technical Forum 4 03-12-2018 11:04 PM
CrankyGypsy's 2004 Rubicon CrankyGypsy Jeep Builds 33 05-14-2017 09:03 PM
