Front seal install tool - JeepForum.com
post #1 of 8 Old 07-15-2019, 08:19 PM Thread Starter
Mr. Puddles
I'm fixing to have to replace a leaking front seal. I remember someone talking about a crank seal install tool but I'm drawing a blank in trying to find one. Can anyone help me out?
Sent from my LM-V405 using Tapatalk
Follow the build!
2002 Dakota aka Winnie aka Mad Max
1996 Grand Cherokee aka Puddles aka Pikey Life
Originally Posted by kg6mov View Post
The 4.0 is dumb old tractor motor, itís too stupid to know itís supposed to die.
Mr. Puddles is offline
post #2 of 8 Old 07-15-2019, 10:39 PM
wkbear
wkbear's Avatar
That would be @wingless
1995 Grand Cherokee Ltd., 5.2, 249, stock (for now)
wkbear is offline
post #3 of 8 Old 07-16-2019, 02:21 AM
Timo_90xj
Timo_90xj's Avatar
It is a nice tool and makes installing easier, but it is not a 100% necessity. At your own risk though, if you're not careful without the tool, it's possible to misalign the timing cover, which will cause a front seal leak.
I haven't had any issues with mine on the V8, no tool used. However, I did use the damper to help in aligning the timing cover.
I did the same thing on my XJ 4.0 years ago, worked just fine. That being said, if you can find the tool at a nice low price, why not.
***Under construction***
Timo_90xj is offline
post #4 of 8 Old 07-16-2019, 05:16 AM
Boone96ZJ
or... a block of wood, hammer until flush
96 5.2 242 3" 32x11.5
https://www.jeepforum.com/forum/f13/1996-grand-cherokee-laredo-5-2-a-2570290/
Boone96ZJ is offline
post #5 of 8 Old 07-16-2019, 05:34 AM
Timo_90xj
Timo_90xj's Avatar
Seal itself is the easy part if the timing cover is out of the engine, and seal can be installed with whatever method is desired. I used a block of wood and a hammer. However, when re-installing the timing cover back to the engine, it needs to be properly aligned in relation to crankshaft - that's where the installation tool is handy. But like I wrote, damper can be used to aid in aligning the seal.
If replacing the seal with the timing cover not removed from the engine, the seal installation tool helps a lot.
post #6 of 8 Old 07-16-2019, 06:02 AM
wingless
wingless's Avatar
1994 ZJ
This reply shows the Miller 6635 tool for locating the timing cover to be concentric to the crankshaft.
wingless is offline
post #7 of 8 Old 07-16-2019, 08:32 AM
zjosh93
I just used the harmonic damper to align them like Timo said. It's been 8 or 9 years since I replaced the timing chain with no leaks so it must be fairly well aligned. The Miller tool runs around $90 or so.
I have a set of PVC seal installers I made to let me install seals over shafts (crank, trans input, etc.). Just sections of pipe with fittings welded to the end. You can get a pretty full range of sizes if you mix and match bits.
zjosh93 is offline
post #8 of 8 Old 07-16-2019, 12:04 PM Thread Starter
Mr. Puddles
I installed the seal in the cover off the engine when I was building the engine last year. It started leaking about 3 months after I got it on the road. If I get above half throttle she starts smoking. Add in the rubber is staring to disintegrate and I'm going to replace the pulley at the same time. I'm just getting tired of leaving oil slicks where ever I go.
Follow the build!
