I just picked up a zj. It's a 94 limited 5.2
I have an ugly sound coming from the pumpkin when moving forward. I was told I could rip the gearing out and run 2 wheel drive. I wanted to know if this was true, if so what is the best way to do it??
It is possible, yes. After you remove the ring gear and carrier you would also need to remove the inner halves of both axle shafts.
If you do this, you MUST leave the outer halves of both axle shafts in place with the axle nuts torqued to 175 ft. Lbs. or the front bearing hubs will come apart and your front wheels will fall off. You can separate the shafts by removing the u-joints.
Edit: upon seeing that you have a 1994 5.2 with presumably a NP249(AWD) transfer case, you have CV joints instead of u-joints, and I don't think a first gen. 249 would like not having gears in front.
Yup, even the 2wd's use stub shafts with the same unit hubs. The 175ft/lbs you put on the axle nuts is the preload for the wheel bearing, you gotta get it right.
in a week or so i am going to have 3.73 R&P gears and carrier and bearings. PM me and we can set something up for you, would be easier and likely cheaper than buying ones from a salvage yard or something.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
