Front brakes on 97 ZJ - JeepForum.com
post #1 of 6 Old 04-17-2015, 05:21 PM Thread Starter
Bigdaddyof4
When bleeding the brakes during a front brake job, do you have to bleed all four or just the front?
Bigdaddyof4 is offline
post #2 of 6 Old 04-17-2015, 07:28 PM
Scrubberguy
Master cylinders are supposed to be separated as two systems, front and back. not sure if the reservoir is also separate so be careful you don't run it dry while bleeding.
Usually I remove fluid from the master cylinder before compressing the caliper. after compressing the caliper pistons I remove more fluid and add fresh and then bleed what's left of the old fluid out of the lines.
Scrubberguy is offline
post #3 of 6 Old 04-18-2015, 12:33 PM
AVR2
You probably know this, but if by "brake job" you mean you're just replacing the pads, there's no need to bleed the brakes. You don't open up any of the brake lines to do that, so no air can get in.
AVR2 is offline
post #4 of 6 Old 04-18-2015, 05:40 PM Thread Starter
Bigdaddyof4
Thanks for the replies. All I did was replace the rotors and pads.
post #5 of 6 Old 04-18-2015, 10:22 PM
rednecktrucker
Use a c clamp to compress the piston. That way no bleeding needed.
94 GRAND CHEROKEE 4.0 5 SPEED 4X4
2004 CHEVY SILVERADO Z71
rednecktrucker is offline
post #6 of 6 Old 04-19-2015, 05:24 AM
PolkaPower
PolkaPower's Avatar
When bleeding the brakes, start furthest from the master cylinder and work forward.
PolkaPower is online now
