Filter casing down my front LH wheel - JeepForum.com
post #1 of 9 Old 01-18-2020, 02:34 AM Thread Starter
Pez97
Hi Everyone, I have a 1996 ZJ, have done a 5.5 inch suspension lift and currently running 35s. Just in front of the LH front wheel is what looks like a casing of some sort. Its in a pretty vulnerable position. What is this thing and can it be removed or replaced? See attached photos
Pez97 is offline
post #2 of 9 Old 01-18-2020, 02:35 AM Thread Starter
Pez97
Heres another pic fyi
Pez97 is offline
post #3 of 9 Old 01-18-2020, 10:15 AM
wingless
wingless's Avatar
1994 ZJ
Welcome to the forum.
That is the fuel charcoal canister. It hold fuel vapors for burning in the engine instead of venting to the atmosphere.
Just return the vehicle to the stock configuration for complete protection.
wingless is offline
post #4 of 9 Old 01-18-2020, 11:30 AM Thread Starter
Pez97
Awesome Thanks for that. Can u just explain a bit more on how to set it to the stock configuration?
Cheers
Pez97 is offline
post #5 of 9 Old 01-18-2020, 11:39 AM
Timo_90xj
Timo_90xj's Avatar
Remove the charcoal canister and relocate it in the engine compartment. My canister has been sitting between air intake tube and master cylinder for the past 9 years.
Wingless meant if you had a stock bumper the canister would be somewhat hidden. That being said, it certainly isn't protected under there.
***Under construction***
Timo_90xj is offline
post #6 of 9 Old 01-18-2020, 08:12 PM Thread Starter
Pez97
Awesome thanks for the help
Pez97 is offline
post #7 of 9 Old 01-19-2020, 11:06 AM
LouC
2007 WK
And if you live in a place that requires inspection each year and the check engine light must be OFF to pass, don't get rid of it, because it has to be functional for you to have the check engine light OFF.
2017 JK Unlimited Sport 6 spd
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline
post #8 of 9 Old 01-19-2020, 12:02 PM
Timo_90xj
Timo_90xj's Avatar
As long as the hoses are connected to the canister, it doesn't really matter where it is located.
post #9 of 9 Old 01-20-2020, 11:48 AM Thread Starter
Pez97
Thanks guys....i have relocated it now, and just kept it all connected. Obviously its there for a reason so might as well have it if I can.
Pez97 is offline
