Few quick control arm questions. - JeepForum.com
 1Likes
  • 1 Post By kg6mov
post #1 of 8 Old 04-15-2019, 03:50 PM Thread Starter
BigRedCornhead
How many are there altogether 4 a piece? Or only 3 up front. Does any grease the bushing before installation? Is alignment needed afterward? Thanks very much for any help.
BigRedCornhead is offline
post #2 of 8 Old 04-15-2019, 04:02 PM
firebane
8
OEM don't get greased
Always
firebane is offline
post #3 of 8 Old 04-15-2019, 07:04 PM
kg6mov
Hears the voices
kg6mov's Avatar
4 in the front, 4 in the back. Think about your track bar bushings at the same time.
GOLDWING likes this.
kg6mov is offline
post #4 of 8 Old 04-15-2019, 11:25 PM
GOLDWING
GOLDWING's Avatar
^^^^ Smart men, good advice. Go with a 3 piece Moog poly bushing on the track bar axle end.......You are going to do the track bar bushing for another $20 right?
GW
"The Dude Abides"
GOLDWING is offline
post #5 of 8 Old 04-16-2019, 01:51 AM
Kolak
Vendor
Kolak's Avatar
Is your Jeep lifted or stock height?
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #6 of 8 Old 04-16-2019, 02:08 AM
wingless
wingless's Avatar
1994 ZJ
This reply shows all the bushings and control arms that I used to restore like-new handling to my ZJ.
The loose bolts are tightened to specifications with the vehicle on the ground and the weight sitting on the wheels, per the FSM.
My alignment tools were used to attain proper FSM settings at home.
The front tie rod end parts have grease Zerk fittings.
wingless is offline
post #7 of 8 Old 04-16-2019, 10:24 AM Thread Starter
BigRedCornhead
She is stock height and my DD, and she feels like the cab wants to fall off the frame rails. I will start ordering parts in the next week so thank you for the replies. I also just saw wingless's linked post, that this new to me ZJ, has the Up Country Suspension Group Package so now im off googling that. I love this little Jeep GC, you all will get tons of random off the wall questions from me on this. I still need to buy and impact, new shocks and number control arms. The guy i bought it from stated he did the track bar very recently. The steering is nice and tight, just feels as though it going to fall off the frame rails going around corners etc.
post #8 of 8 Old 04-17-2019, 01:02 AM
Kolak
Vendor
Kolak's Avatar
Check the bushings in the rear trackbar too. While you're at it, check the swaybar endling and bar mount bushings for wear.
If I can assist with any parts, please PM me here on the forum or email me at [email protected]
or
Kolak is offline
Rear control arm bushing play voltquad WK Grand Cherokee & XK Commander Forum 8 04-10-2019 09:32 AM
Control Arm Questions? joeyroe TJ Wrangler Technical Forum 15 04-06-2019 10:01 AM
Rear upper control arm & ball joint replacement advice/help three_jeeps WJ Grand Cherokee Forum 21 03-30-2019 05:32 AM
New TERAFLEX FRONT CONTROL ARM SPORT BRACKET FOR JL/JLU Rockridge4WD Vendor Display 0 10-11-2018 02:15 PM
Adjustable control arm setup help arg0413 TJ Wrangler Technical Forum 7 12-01-2017 06:36 AM
